我正在使用6674A通过额外的电源开关卡为UUT供电。
可以通过隔离电源线而不隔离感测线来损坏电源的远程感测电路。 即,是否需要将感测线和电源线一起切换,或者我可以独立于感测线切换电源线。 在此先感谢尼克 以上来自于谷歌翻译 以下为原文 I am using a 6674A to supply a UUT through an additional power switching card. Can the power supplies' remote sense circuit be damaged by isolating the power lines without isolating the sense lines. i.e. Is it a requirement to switch the sense lines and power lines together or can I just switch the power lines independently of the sense lines. Thanks in advance Nick |
你好Nick,在内部,+ S / + O和-S / -O之间有10kΩ电阻。
将±S引线与±输出引线“断开”应该没有问题。 但是,请记住,内部电阻会保持这些连接,并且指定的电源性能会受到影响(编程精度,调节等)。 它们实际上并没有完全“浮动”。 此致,PeterW 以上来自于谷歌翻译 以下为原文 Hello Nick, Internally, there are 10kΩ resistors between +S/+O and -S/-O. There should not be a problem "disconnecting" the ±S leads from the ±Output leads. However, keep in mind that the internal resistances maintain these connections and specified power supply performance will suffer (Programming accuracy, Regulation, etc.). They do not actually become entirely "floating". Regards, PeterW |
1291 浏览 0 评论
2375 浏览 1 评论
2194 浏览 1 评论
2065 浏览 5 评论
2952 浏览 3 评论
1120浏览 1评论
756浏览 0评论
931浏览 0评论
1293浏览 0评论
GMT+8, 2024-12-25 22:36 , Processed in 1.380269 second(s), Total 78, Slave 62 queries .
