使用AD8367俩级级联采用电压控制,结果产生自激。使用的电路采用AD8367文档提供的LC参数匹配电路,用于使用140MHz增益控制,一级测试问题不是很大,俩级级联后在控制电压0.05-0.4V间自激产生,几乎没有增益。俩级间级联目前只使用了π型衰减网络连接,并且输入输出为一直线设计,俩级间并未采用物理隔离。自己是个菜鸟,印制板采用普通的,板厚1.6MM。有没有高手指导下解决办法,具体是什么引起。AD8367外围电路元器件很少,不清楚是不是印制板设计问题。
4个回答
您好,您的问题已经提交给ADI相关专家,将邀请专家尽快回答您的问题。谢谢!
您好!
对于级联AD8367的使用产品线工程师建议如下,供您参考。 This is not the first time cascaded AD8367 have been used to extend the dynamic range. There are a few things one must keep in mind while cascading the VGAs to extend the dynamic range: 1) The input linearity of the cascade will be very low at high gain settings 2) The sensitivity will be poor at low gain settings 3) High max gain and high bandwidth devices like the AD8367 may be potentially unstable, and it may be necessary to apply some resistive padding between the stages to ensure a stable solution. Starting with the third point, it will likely be necessary to add ~10dB of padding between the two VGA's (or all three VGAs if you need it, right now, I’ll just speak to two cascaded VGAs). The AD8367 needs to be sourced and loaded in a 200-Ohm impedance environment to ensure stability. However, the output of the AD8367 presents a 50-Ohm impedance. If you directly cascade the devices the 2nd stage VGA will be presented by the 50-Ohm impedance of the first stages output, and may cause the 2nd stage to oscillate. As a result a 200-Ohm to 200-Ohm resistive pad will likely be needed between the two stages. A 10dB pad should be enough to isolate the 50-Ohm source impedance of the first stage VGA from the input of the second stage. If the cascade is properly stabilized, you should be able to achieve ~90dB of gain adjustment range. |
你好。文中A 10dB pad,没有理解是什么意思,是不是一个10dBπ型衰减网络??目前设计的电路俩级AD8367,单独测试均没有任何问题,电路完全是按照手册中LC匹配进行设计,如果是输入200欧的话,应该手册中给的第一级输出是50。第二级中的LC网络进行匹配应该是按照200进行的。我周一在直接加个10dBπ型衰减网络尝试下。有没有级联的电路给分享一下,谢谢。
chenliang513 发表于 2019-3-5 12:33 您好! 是10dBπ型衰减网络。ADIsimRF中有T型衰减网络的模型。ADIsimRF可从ADI官网免费下载。 |
2319个成员聚集在这个小组
加入小组1229 浏览 2 评论
1563 浏览 2 评论
2077 浏览 1 评论
4382 浏览 2 评论
9223 浏览 1 评论
2084浏览 3评论
1834浏览 2评论
1232浏览 2评论
1865浏览 2评论
1563浏览 2评论
GMT+8, 2025-4-8 21:06 , Processed in 0.991732 second(s), Total 83, Slave 67 queries .
