扫一扫,分享给好友
喜
我在Windows XP上安装了xilinx ISE 10.1。 我在地图中遇到了一些时间问题,所以我在ISE的tcl窗口中将xil_timing_allow_impossible设置为1。 地图经历了。 但是,现在当我将xil_timing_allow_impossible重置为0时,即使我在后映射时序报告中可以看到一些时序违规,地图仍然成功完成。 我用来设置env变量的语法是 - %set env(XIL_TIMING_ALLOW_IMPOSSIBLE)1 1 %echo $ env(XIL_TIMING_ALLOW_IMPOSSIBLE) 1 我用来重置env变量的语法是 - %set env(XIL_TIMING_ALLOW_IMPOSSIBLE)0 0 %echo $ env(XIL_TIMING_ALLOW_IMPOSSIBLE)0 所以我甚至设置/重置这个环境。 变量合适吗? 或者我在语法中遗漏了什么? 如果我正确地重置变量,那么即使有时间违规,下一次地图也会如何通过。 帮帮我! ž。 以上来自于谷歌翻译 以下为原文 hi, i have xilinx ISE 10.1 on windows XP. i had some timing issues in map so I set the xil_timing_allow_impossible to 1 in the tcl window in ISE. the map went through. however, now when I reset the xil_timing_allow_impossible back to 0, map is still completing successfully, even though I can see some timing violations in the post map timing report. the syntax I used to set the env variable is - % set env(XIL_TIMING_ALLOW_IMPOSSIBLE) 1 1 % echo $env(XIL_TIMING_ALLOW_IMPOSSIBLE) 1 the syntax I used to reset the env variable is - % set env(XIL_TIMING_ALLOW_IMPOSSIBLE) 0 0 % echo $env(XIL_TIMING_ALLOW_IMPOSSIBLE) 0 So am I even setting/resetting this env. variable properly? or am I missing something in the syntax? And if I am resetting the variable properly, how come map goes through next time around, even when there are timing violations. Help! z. |
4个回答
嗨,一旦修改变量后你关闭了ISE并重新启动了吗?请尝试重新启动工具并修改变量.Regards,Achutha
-------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hi, Once after modifying the variable have you closed the ISE and relaunch ? Please try to re-launch the tool and the variable is modified. Regards, Achutha --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
我确实重新推出了ISE,然而,在我再次发布之后,当我这样做时 -
echo $ env(XIL_TIMING_ALLOW_IMPOSSIBLE) 我收到错误消息 - 无法读取“env(XIL_TIMING_ALLOW_IMPOSSIBLE)”:没有这样的变量 我需要在重新启动后重置此env变量然后回显吗? 我会假设,因为它的xilinx env变量,它应该显示prev。 设定的价值...... 以上来自于谷歌翻译 以下为原文 i did relaunch ISE, however, after launching it again, when i do - echo $env(XIL_TIMING_ALLOW_IMPOSSIBLE) i get the error message - can't read "env(XIL_TIMING_ALLOW_IMPOSSIBLE)": no such variable do i need to reset this env variable after relaunching and then echo it? i would assume since its a xilinx env variable, it should show the prev. value that was set ... |
我认为这些工具正在检查环境变量是否完全定义而不是它的值。
因此,删除变量是正确的做法,而不是将其设置为零。 删除后,您是否尝试再次运行流程? - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 I think the tools are checking whether the environment variable is defined at all and not the value of it. So removing the variable is the right thing to do instead of setting it to zero. Did you try running through the flow again after removing it?- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
香港专业教育学院做了以下(按顺序) -
-set xil_timing_allow_impossible为0 - 关闭我可能打开的所有ISE实例 - 关闭电脑 - 重新启动计算机,再次打开项目 -cleanup项目 - 再次运行地图......但是地图仍然成功,即使在后期地图时间报告中,也有失败和错误! xil_timing_allow_impossible的回声再次说 - 变量不存在。 我怎么能重置这个变量??????????????? 请帮忙!! :( :( 以上来自于谷歌翻译 以下为原文 ive done the following (in sequence) - -set the xil_timing_allow_impossible to 0 -shut down all the ISE instances i might have open -shut down the computer -restart the computer, open the project again -cleanup project -run the map again ... BUT map is still succeeding, even though in the post map timing report, there are failures and errors! echo of xil_timing_allow_impossible again says - variable not present. how else can i reset this variable???????????????? please help!! :( :( |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
201浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 10:29 , Processed in 1.083826 second(s), Total 54, Slave 48 queries .
