你好,
我爸爸在我的代码中写了“#include”。 然而,仍然存在错误“数学函数'pow'不支持合成”。我选择哪个C库或者我用什么功能来获得数字的功率? 我试着自己编写pow函数以获得2的幂,代码如下: int power_func(int n){int power = 1,k; 为(K = 0; k 以下为原文 Hello, I dad write "#include I tried to write the pow function myself to get the power of 2 ,codes like: int power_func(int n) { int power=1,k; for(k=0;k<=n-1;k++) { power=power*2; } return power; } The trip count and lentancy both are "?". Maybe because n is an variable. What can I do for the power? Thanks a lot! |
3个回答
做一些代数:根据定义pow(x,y)= exp(y * log(x))。
exp和log都可用于综合。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Do some algebra: By definition pow(x,y) = exp(y*log(x)). Both exp and log are available for synthesis. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented.View solution in original post |
exp和log都可用于综合。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 Do some algebra: By definition pow(x,y) = exp(y*log(x)). Both exp and log are available for synthesis. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2626浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-6 23:32 , Processed in 1.149390 second(s), Total 50, Slave 44 queries .
