扫一扫,分享给好友
你好,
我想在nexys 3板上处理一个文本文件,我创建了一个std.textio librairie,这个librairy允许我读取和写入文件文本,我用modelSim测试它,它的工作原理。 现在我想对待我的主板上的文件,但我不知道怎样才能在主板上找到我的文本文件... 我应该从我的电脑上加载它(jatg)? 如果我从串行连接接收文件并将其存储在内存中,我可以使用该文件吗? Librairy有效吗? 谢谢 PS:对不起我的坏英格丽... 以上来自于谷歌翻译 以下为原文 Hello, I would like to treat a text file on a nexys 3 board, I founded a std.textio librairie, this librairy allow me to read and write in a file text, I had tested it with modelSim and it works. Now I want to treat the file on my board, but I don't know how can I found my text file on the board... Should I load it from my computer(jatg) ?? Could I use the file if I receive it from a serial connection and I store it in a memory ? Librairy works ? Thanks PS : Sorry for my bad Englis... |
该库仅用于模拟,不可合成。
您需要创建特定的硬件才能执行此操作并将其添加到您的设计中。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The library is for simulation only and is not synthesizable. You will need to create specific hardware to do this and add it to your design.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2423 浏览 7 评论
2824 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2465 浏览 15 评论
1198浏览 1评论
590浏览 1评论
452浏览 1评论
2006浏览 0评论
731浏览 0评论
GMT+8, 2024-12-24 13:40 , Processed in 1.147221 second(s), Total 48, Slave 42 queries .
