我正在学习如何使用CY3684开发板。我是遵循EZ-USB高级开发工具包用户指南中的教程的,但是在第三教程中我遇到了问题——我不能使用Keil UVISION 3连接到板。我猜想可能有人弄乱了工具箱,所以我试图恢复监视器。使用EZ-USB接口软件,我已经把监视器加载到DEV板(MON-EXT-SIO1-C0. HEX),但我仍然无法连接到电路板。下载显示器后,绿色LED D7亮起来,但这是唯一的效果,它似乎有。EZ-USB接口返回的VID和PID分别为0x04B4和0x8613。我做错什么了吗?如何在下载监视器时设置选择EEPROM并启用EEPROM交换机?谢谢你的帮助。
以上来自于百度翻译 以下为原文 I'm learning how to use the CY3684 development board. I was following the tutorials in the EZ-USB Advanced Development Kit User's Guide but I've encountered problems right at the 3rd tutorial - I'm not able to connect to the board using Keil uVision3. I assumed that somebody might have messed up the kit so I tried to restore the monitor. Using the EZ-USB Interface software I've dowloaded the monitor to the dev board (mon-ext-sio1-c0.hex) but I'm still unable to connect to the board. After downloading the monitor the green LED D7 lights up but that is the only effect it seems to have. The VID and PID returned by the EZ-USB Interface is 0x04B4 and 0x8613, respectively. Am I doing something wrong? How should I set the Select EEPROM and Enable EEPROM switches when downloading the monitor? Thanks for any help. |
似乎小EEPROM的内容被损坏了。我设法恢复它(使用这里描述的程序:HTTP://wwwyCyp.com)?RID=34127)。EEPROM现在包含C0 B4 04、82、00、00、00、00。它列举了EZ-USB高级开发板FX2LP(Keil监视器)和绿色LED D7灯在每次我重置板。但是,我仍然无法连接到Keil UVIEW的董事会。UVIEW中的COM端口设置是COM1和38400,我相信这是正确的。有什么想法吗?
以上来自于百度翻译 以下为原文 It seems that the contents of the small EEPROM was damaged. I managed to restore it (using the procedure described here: http://www.cypress.com/?rID=34127). The EEPROM now contains C0 B4 04 82 00 00 00 00. It enumerates as EZ-USB Advanced Development Board FX2LP (Keil monitor) and the green LED D7 lights on everytime I reset the board. However, I'm still not able to connect to the board from Keil uVision. The COM port settings in uVision are COM1 and 38400 which I believe is correct. Any ideas what could be wrong? |
问题解决:在问题与EEPROM在我的计算机COM口的问题。
以上来自于百度翻译 以下为原文 Problem solved: beside the problem with the EEPROM there was a problem with the COM port in my computer. |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
572浏览 2评论
424浏览 2评论
438浏览 2评论
386浏览 2评论
916浏览 2评论
GMT+8, 2024-12-24 21:39 , Processed in 0.885837 second(s), Total 78, Slave 62 queries .
