任何人都可以帮我设计具有以下参数的差分共面线:差分阻抗= 100欧姆。
地面和信号线之间的间距= 50 - 60 um信号线之间的间距= 50-60 um走线宽度约= 30-40 um你可以使用基板的选择:Er = 3.66,2.33,2.20,6.15,10和 PCB厚度= 0.1毫米迹线厚度= 0.7密耳或1.4密耳。 请回复是否有人可以使用这些参数设计或任何人都知道如何做到这一点。 ......... Mukul Ratwani印度理工学院研究助理孟买孟买,印度 - 400076电话:+ 91-9004045732 以上来自于谷歌翻译 以下为原文 Can anybody help me to design differential co-planar lines with the following parameters: Differential impedance = 100 ohm. spacing between ground and signal line around = 50 - 60 um spacing between signal lines around = 50-60 um trace width around = 30-40 um you can use the choice of substrate: Er = 3.66, 2.33, 2.20, 6.15, 10 and thickness of PCB around = 0.1 mm trace thickness = 0.7 mil or 1.4 mil. Please reply if anyone can design using these parameter or anyone have idea how to do this. ......... Mukul Ratwani Research Assistant Indian Institute of Technology Bombay Mumbai, India- 400076 Ph:+91-9004045732 |
这可以使用Line Engineer Lite设计套件完成:[http://edocs.soco.agilent.com/display/eesofkcads/Line+Engineer+Lite]尝试宽度= 32.4 um线间距= 60 um间距到GND =
60 um T = 1.4 mil Er = 6.15 以上来自于谷歌翻译 以下为原文 This can be done using the Line Engineer Lite Design Kit: [http://edocs.soco.agilent.com/display/eesofkcads/Line+Engineer+Lite] Try Width = 32.4 um Spacing between lines = 60 um Spacing to GND = 60 um T = 1.4 mil Er = 6.15 |
1511 浏览 0 评论
2492 浏览 1 评论
2339 浏览 1 评论
2189 浏览 5 评论
3123 浏览 3 评论
1711浏览 1评论
919浏览 0评论
1511浏览 0评论
GMT+8, 2025-4-23 05:43 , Processed in 1.209710 second(s), Total 75, Slave 59 queries .
