你好,我想用柏树一我的DAQ板接口到PC。你们能给我点一些链接,我在哪里可以找到入门的文档/参考设计等,我用max3420e全速USB接口芯片。我不知道如何与EZ USB以外的速度,如编码复杂度等我用一个FPGA程序/配置的数字信号处理器。我认为公司有芯片无8051,这意味着要与FPGAs、UC等我试图决定之间的芯片没有8051和8051。我需要什么工具来编程8051?谢谢你的耐心。
以上来自于百度翻译 以下为原文 Hi, I would like to use cypress for one of my DAQ boards to interface it to PC. Can you guys point me to some links where I can find getting started documents/reference designs etc. I have used the MAX3420E Full speed u*** interface chip. I am not sure how it compares with Ez USB other than speed, like coding complexity etc. I used an FPGA to program/configure the MAX3420. I think cypress has a chip without the 8051, which is meant to be interfaced with FPGAs, uC etc. I am trying to decide between the chip without 8051 and with 8051. what tools do I need to program the 8051. Thanks for your patience. |
你好,我也有和你一样的问题。我想使用CY7C68013A控制器,但不知道用哪种方式。你有没有发现一些好的文件,或有任何其他人一些建议我怎么开始与该控制器。请给我一些帮助。
以上来自于百度翻译 以下为原文 Hello, I have the same problem like you. I want to use the CY7C68013A controller, but don't know in which way. Have you find some good documents, or have any othher person some suggetions how can I start with this controller. Please give me some help. |
开发工具包是最简单的方法。赛普拉斯售价400美元左右。如果这不是一个选项,我遇到另一个公司为CyPress - http://www.获取RealReDeCix.COM/PIKE.JSP更多USB 2套件- http://www-BuydLogiq.Org/Ubb/UsBurd2.HTM一些入门笔记-http://www-Dead相关…com dd/St/608201.PHP基本上,您需要编写代码并将其下载到8051。流行的工具是KEIL和SDCC(小设备C编译器)。
以上来自于百度翻译 以下为原文 Getting a development kit is the easiest way. Cypress sells one for around 400$. If thats not an option, I came across another company which makes USB kit for cypress - http://www.acquiredevices.com/pike.jsp More USB 2.0 kits - http://www.beyondlogic.org/u***/u***hard2.htm Some getting started notes - http://www.embeddedrelated.com...dded/show/60820-1.php Basically, you need to write your code and download it to 8051. The popular tools are keil and sdcc(small device C compiler). |
741个成员聚集在这个小组
加入小组2005 浏览 1 评论
1766 浏览 1 评论
3552 浏览 1 评论
1697 浏览 6 评论
1466 浏览 1 评论
277浏览 2评论
177浏览 2评论
356浏览 2评论
299浏览 2评论
491浏览 2评论
GMT+8, 2024-9-23 07:24 , Processed in 0.844119 second(s), Total 80, Slave 64 queries .
