Hii,我需要对Cordic i / p进行一些澄清。
这里的问题是,由于ADC的输出是标量,所以可以直接将它们传递给Cordic ip核心......? 或者我们是否需要将i / p发送给Cordic作为Vector类型..?谢谢你,Ajay Kumar K. 以上来自于谷歌翻译 以下为原文 Hii, Here I need some clarification on Cordic i/p's. Here the issue is, As the outputs from ADC are scalar so that is it possible to pass them i/p's to Cordic ip core directly...? Or should we need to send the i/p's to Cordic as Vector type..? Thank You, Ajay Kumar K. |
嗨,
CORDIC算法可以执行许多功能,并且这些功能有时在输入上具有不同的数值范围。 ADC值通常是参考电压的整数分数。 因此可能需要以有意义的方式转换/对齐它们,因此它们符合CORDIC输入规范。 否则,可能难以解释CORDIC输出。 检查CORDIC-IP文档中的数值范围,并将这些规格与ADC输出的数字表示进行比较。 (比特是比特,对其含义的解释取决于设计师。) 有一个很好的综合 Eilert 以上来自于谷歌翻译 以下为原文 Hi, the CORDIC algorithm can perform many functions amd these sometimes have different numerical ranges on the input. Your ADC values are normally integer fractions of the reference voltage. So it might be necessary to convert/align them in a meaningful way, so they comply to the CORDIC inputs specifications. Otherwise it might become difficult to interpret the CORDIC output. Check the CORDIC-IP documentation for the numerical ranges and compare these specs with the numerical representation of your ADCs output. (Bits are bits, interpretation of their meaning is up to the designer.) Have a nice synthesis Eilert |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2629浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-7 06:27 , Processed in 1.269638 second(s), Total 77, Slave 61 queries .
