我今天正在实现FIFO,我想知道FIFOPrimitive和Block RAM实现之间的区别是什么。
根据我的理解,它们使用相同的底层RAM原语,但FIFOPrimitive不能有不同的R / W方面或双时钟域。 除了向导中列出的明显限制外,还有哪些其他差异? FIFOPrimitive在Block RAM上有什么优势? 为了记录,我正在使用6系列Virtex,但这适用于任何具有我认为的FIFOPrimitive的家庭。 提前感谢您的想法! 以上来自于谷歌翻译 以下为原文 I was implementing a FIFO today and I was wondering what the difference between the FIFO Primitive and the Block RAM implementations are. From what I can understand, they use the same underlying RAM primitives, but the FIFO Primitive can't have different R/W aspects or dual clock domains. Other than the obvious limitations which are outlined in the wizard, what are the other differences? What advantage does the FIFO Primitive give you over the Block RAM? For the record, I'm using 6-series Virtex, but this would apply to any family that has the FIFO Primitive I would think. Thanks in advance for your thoughts! |
V6在FPGA的块ram中包含一些FIFO逻辑。
如果已经使用块ram并且符合FIFO原语的功能,这应该减少实现FIFO所需的资源。 请参阅ug363第43页的概述: http://www.xilinx.com/support/documentation/user_guides/ug363.pdf 虽然我已经使用了fifo原语,但我没有花时间用coregen的通用块ram fifo来实现它,并比较实现资源,如果你这样做,请在这里发布你的结果:)。 以上来自于谷歌翻译 以下为原文 V6 includes some FIFO logic in the block ram of the FPGA. This should reduce the resources needed to implement a FIFO if it is already using a block ram and fits the capabilities of the FIFO primitive. See the overview on page 43 of ug363 : http://www.xilinx.com/support/documentation/user_guides/ug363.pdf Although I have used the fifo primitive I have not taken the time to implement the same with a generic block ram fifo from coregen and compare the implementation resources, if you do so please post your results here :). |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2312浏览 1评论
649浏览 1评论
514浏览 1评论
2062浏览 0评论
790浏览 0评论
GMT+8, 2025-2-12 08:27 , Processed in 1.107723 second(s), Total 42, Slave 37 queries .
