我正在尝试配置万用表,以便我可以获得我想要的采样率,光圈设置为采样周期的2倍或更大。
例如:SampleInterval = 0.005即。 每秒200个样本。 Aperture = 0.01我尝试了这些设置,但我得到的样本数量只有48-49。我需要做些什么来实现这一目标? 以上来自于谷歌翻译 以下为原文 I am trying to configure the multimeter such that I can obtain the sample rate I want with aperture set to 2X the sample period or greater. For example: SampleInterval = 0.005 ie. 200 samples per second. Aperture = 0.01 I tried these settings but the number of samples I got is only 48 - 49. What do I have to do to achieve this? |
嗯,你不能采用每秒200个采样(200 Hz),积分时间(ADC测量时间)为10毫秒。
即使没有其他开销(例如自动调零),最快的理论速率将是1/10 ms或100 Hz(每秒100个样本)。 但是,通过自动调零等功能,可以降低最大采样率。 页面引用来自用户指南Aperture是A / D转换的积分时间,以秒为单位。 (第115页)。 或者,您可以设置电源线周期数,以最大限度地减少交流电源拾取时的错误。 Interval是一个数据记录参数,是读数之间的时间,也是秒。 INTERVAL是后续读数之间的时间(20μs至3599.99999 s)。 (第78页)。 如果你想要快速,你需要查看Auto Zero等功能,默认情况下处于启用状态。 自动调零会降低读取速度(第116页)。 要获得最大读取速度,请关闭自动调零。 这将使直流电压,电阻和直流电流功能的读取速度提高一倍以上。 Autozero不适用于其他测量功能。 (第118页)。 您可以从前面板试验数据记录。 首先,(例如在DCV模式下),使用配置按钮设置光圈。 然后,在数据记录中,尝试设置间隔。 间隔只会与您的设置一样低,例如自动调零,允许。 此外,您可以设置所需样本的数量,并查看结果持续时间,数据记录器设置的所有部分。 以上来自于谷歌翻译 以下为原文 hmm, you cannot take 200 samples per second (200 Hz) with an integration time (ADC measurement time) of 10 milliseconds. Even if there were no other overhead (e.g. autozero), the fastest theoretical rate would be 1/10 ms or 100 Hz (100 samples per second). However, with features such as auto zero on, the max sample rate is reduced. Page references are from the User's Guide Aperture is the integration time for the A/D conversion in seconds. (page 115). Alternatively, you can set number of power line cycles to minimize error from AC mains pickup. Interval is a data logging parameter, is the time between readings, also in seconds. INTERVAL is the time (20 μs to 3599.99999 s) between subsequent readings. (page 78). If you want to go fast, you need to look at features like Auto Zero, which is on by default. Auto Zero reduces reading speed (page 116). For maximum reading speed, turn autozero off. This will more than double your reading speeds for dc voltage, resistance, and dc current functions. Autozero does not apply to other measurement functions. (page 118). You can experiment with data logging from the front panel. First, (e.g. in DCV mode), set your aperture using the configure button. Then, in Data logging, experiment with setting the interval. Interval will only go as low as your settings, such as auto zero, allow. Also, you can set the number of desired samples, and look at the resulting duration, all part of the data logger setup. |
自动量程的另一个因素可能是7.5毫秒;
看到这篇较老的帖子:相关文章:34411自动归零和自动量程时间 以上来自于谷歌翻译 以下为原文 Another factor might be 7.5 ms for autorange; see this older post: Related post: 34411 auto zero and auto range time |
1356 浏览 0 评论
2409 浏览 1 评论
2238 浏览 1 评论
2093 浏览 5 评论
2984 浏览 3 评论
1322浏览 1评论
801浏览 0评论
1108浏览 0评论
1356浏览 0评论
GMT+8, 2025-2-3 00:08 , Processed in 1.378804 second(s), Total 76, Slave 60 queries .
