我们正在尝试将旧设计重新投入生产,以满足特定客户的需求。
我找到了.bit文件,但无法找到关联的.msk文件。 如果没有.msk文件进行验证,我们的测试部门不会将.bit文件写入FPGA。 有没有办法从现有的.bit文件创建.msk文件,还是需要重新设置设计和创建新文件? 以上来自于谷歌翻译 以下为原文 We are trying to put an older design back into production for a specific customer. I have located the .bit file, but cannot find the associated .msk file. Our test department will not writ a .bit file to an FPGA without a .msk file to verify against. Is there a way to create a .msk file from an existing .bit file, or will I need to re-route the design and creatre new files? |
嗨错开,
抱歉,没有任何办法。您需要重新路由设计以生成.Bit和.msk文件。 谢谢 -Pratham ------------------------------------------------ ----------------------------------------------请注意 - 请 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K- -------------------------------------------------- ----------------------- 以上来自于谷歌翻译 以下为原文 Hi stagger, Sorry there is no any way of doing it.you need to reroute the design for generating .Bit and .msk file. Thanks -Pratham ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
是的 - 这就是我害怕的。
无论如何,谢谢你的回复。 以上来自于谷歌翻译 以下为原文 Yeah - that's what I was afraid of. Thanks anyway, for your reply. |
2308 浏览 7 评论
2718 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
631浏览 1评论
1684浏览 1评论
443浏览 1评论
201浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 12:44 , Processed in 1.373590 second(s), Total 77, Slave 61 queries .
