PIC32启动工具包开关如何工作SW1、SW2、SW3或我们需要配置它们?
以上来自于百度翻译 以下为原文 How pic32 starter kit switch works SW1,SW2,SW3 or we need to configure them? |
5个回答
嗨,对于每一个PIC32 STATER工具包,在标准的和声框架中都有BSP。如果你使用任何标准的BSP,就可以在启动器套件上找到所有的开关和LED的端口引脚映射。随着设备外围库,您将能够读取开关状态,并能够驱动LED关闭。您可以在Hypp://www. MyCHIP.COM/MPLAB/MPLAB-OrthyHyb中找到和声集成软件框架,
以上来自于百度翻译 以下为原文 Hi, For every PIC32 Stater kit, there is BSP available in the standard Harmony Framework. If you are using any of the standard BSPs, PORT Pin mapping for all the switches and LEDs on the starter kit are available. Along with the device Peripheral Library, you would be able to read the switch status and would be able to drive the LEDs ON OFF. You can find the Harmony Integrated Software Framework at http://www.microchip.com/mplab/mplab-harmony Thanks, |
你应该使用61159B.PDF(PIC32初学者工具包用户指南),有开关/ LED和使用的PosiPin的布局。
以上来自于百度翻译 以下为原文 You should work with 61159B.pdf (PIC32 Starter Kit User’s Guide), there is the layout with the switches/LEDs and the used PortPins. |
2.1.4开关按钮开关提供以下功能:SW1:连接到RD6/SW2的有源低开关:连接到RD7/SW3的有源低开关:连接到RD13的有源低开关;开关没有任何去抖动电路,需要使用内部脉冲变压器;他允许你研究反跳威廉希尔官方网站
。怠速时,扳手被拉高(+3.3V)。当按下时,它们是这样被给定的,所以我们需要配置TIS和端口位。
以上来自于百度翻译 以下为原文 2.1.4 Switches Push-button switches provide the following functionality: • SW1: Active-low switch connected to RD6 • SW2: Active-low switch connected to RD7 • SW3: Active-low switch connected to RD13 The switches do not have any debounce circuitry and require the use of internal pullup resistors; this allows you to investigate debounce techniques. When Idle, the switches are pulled high (+3.3V). When pressed, they are grounded Its given like this , So we need to configure tris and port bits for that or not |
嗨,有几个PIC32启动套件,你有哪一个(参考DMS3xxx)?什么是处理器上的启动套件PIC32 MXXXXXXXX,PIC32 MZXXXXXXX?当做
以上来自于百度翻译 以下为原文 Hi, There are several PIC32 starter kits. Which one do you have (reference DM320xxx) ? What is the processor on your starter kit PIC32MXxxxxxxx , PIC32MZxxxxxxxx ? Regards |
零件号:MID32000 1PIC启动器KITPIC32 MX360F512L
以上来自于百度翻译 以下为原文 Part Number: DM320001PIC Starter Kit PIC32MX360f512l |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
486浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-21 00:45 , Processed in 1.021832 second(s), Total 54, Slave 48 queries .
