你好,
我必须用IAR(版本7.80.4使用商业许可证)来构建一个项目。该项目是与PSoC Creator 4.1设置然后连接到IAR通过项目>;出口井手。由于加入了CapSense [ V4.0 ]成分我收到以下错误: 错误[LI016]:超出了大小限制。应用程序需要0x1a29a(107 162)个字节,这是大于0x8000极限(32 768)字节。限制是由于许可证”的手臂。EW。从“capsense_smartsense_sl_v3_10连接器”。O(capsense_p4library_iar。一)”(和其他1个模块)。 这似乎是一个组件(capsense_p4library_iar。一)放在一起,用IAR KickStart版吗? 取出CapSense组件后的一切是好的在IAR和应用还需要更多的比100kbytes。 我可以做什么工作(我已经使用IAR代替PSoC creator)? 谢谢 托马斯 以上来自于百度翻译 以下为原文 Hello, I have to build a project with IAR (version 7.80.4 using a commercial license). The project is set-up with PSoC Creator 4.1 and then connected to IAR via the Project->Export to IDE. Since adding the CapSense [v4.0] component I get the following error: Error[Li016]: size limit exceeded. The application needs 0x1a29a (107 162) bytes, which is greater than the limit of 0x8000 (32 768) bytes. The limit is due to license "ARM.EW.LINKER" from "CapSense_SmartSense_SL_v3_10.o(Capsense_P4Library_IAR.a)" (and 1 other module). It seems like a component (Capsense_P4Library_IAR.a) was put together with the Kickstart edition of IAR? After taking out the CapSense component everything is fine in IAR and the application still needs more than 100kbytes. What can I do to make it work (I have to use IAR instead of PSoC creator)? Thanks Thomas |
3个回答
因此,考虑到你正在使用的项目占用了100 KB,而你的设备只支持32 KB,你认为有一个解决方案而不需要切断几百行代码吗?不太可能。如果你的设备真的只支持32 kb的空间,那么你将需要不断地削减代码/组件,或者增加优化(-O3通常是最大压缩Irc)。否则,你需要一个更大的芯片:
以上来自于百度翻译 以下为原文 So, given that the project you are using is taking up 100 kB, and your device only supports 32 kB, you think there is a solution without cutting out hundreds of lines of code? Not likely. If your device really only supports 32 kB of space, then you will need to keep cutting out code/components, or increasing optimization (-o3 is usually the max compression iirc). Otherwise, you need a bigger chip :) |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1869 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 09:08 , Processed in 0.784614 second(s), Total 50, Slave 44 queries .
