嗨,我正在尝试使用ST1CC40构建一个恒流LED驱动器。我构建了一个原型版本,注意到没有连接负载,输出端会看到整个Vin(在我的情况下是12V)。这是正常的吗?假设Vout应为5V且Vin为12V,当INH引脚拉低时,Vout将接近零。然而,当INH拉高时,Vout会在稳定之前在Vin和Vout之间摆动吗?换句话说,Vout会出现大幅飙升吗?
#st1cc40 以上来自于谷歌翻译 以下为原文 Hi, I'm trying to build a constant current LED driver using the ST1CC40. I built a prototype version and noticed that with no load attached, the entire Vin (in my case its 12V) is seen at the output. Is this normal? In a situation where lets say the Vout is supposed to be 5V and the Vin is 12V, when the INH pin is pulled low, the Vout would be close to zero. However, when the INH is pulled high, would the Vout swing between Vin and Vout before stabilizing? In other words, would there be a massive spike in Vout? #st1cc40 |
2901 浏览 1 评论
3285 浏览 1 评论
1866 浏览 1 评论
3718 浏览 6 评论
6131 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
415浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
515浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
342浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
248浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
357浏览 2评论
GMT+8, 2025-3-7 10:09 , Processed in 1.163683 second(s), Total 43, Slave 38 queries .
