你好,我想问你,如果在MCC的未来版本中会有PIC18F4620的支持。谢谢。
以上来自于百度翻译 以下为原文 Hello, I would like to ask you, if there will be support for PIC18F4620 in future releases of MCC. Thank you. |
3个回答
也许,但不太可能。微芯似乎优先考虑新的PIC模型,他们有很多的投资组合,甚至有很多要发布。最好选择一个新的模型来满足你的需求。一个新的型号可能比你的PIC18F4620便宜。
以上来自于百度翻译 以下为原文 Maybe, but unlikely. It seems Microchip is prioritizing new PIC models and they have got plenty in their portfolio and even plenty to be released. It's advisable to chose a new model which can fulfill your requirements. A new model might be even cheaper than your PIC18F4620. |
谢谢你的建议。但我在这个项目开始前使用MCU的长期项目,在MCC之前的很长一段时间。是否有可能在MCC中添加具有定制资源的“定制”MCU?我发现,在“C:\用户AppDATa\ROMAMMPLABIDID\V3.65 模块ExtMCC 库”中,有一个名为“PIC10-PIC12PIC16-PIC18-1.45 .jar”的文件。它是可执行的Java存档,当我在Wrrar中打开它时,有许多XML文件有MCU的名称。是否存在任何教程如何添加“自定义MCU”到这个库?谢谢您。
以上来自于百度翻译 以下为原文 Thank you for suggestion. But I work on long-term project which uses this MCU from beginning of this project long time before MCC. Is there any possibility to add "custom made" MCU with specified resources in MCC? I found that in "C:UsersuserAppDataRoamingmplab_idedevv3.65modulesextmcclibraries" there is file named "pic10-pic12-pic16-pic18-1.45.jar". It is executable java archive and when i open this in WinRAR, there are many XML files with names of MCUs. Does exist any tutorial how to add "custom MCU" into this library? Thank you. |
你从一个非常老的芯片开始。PIC18F4620在2004出现,并且它的数据表的最后更新是在2008,没有,没有教程,从零开始编写你自己的代码要比修改MCC来处理一个新设备要简单得多。
以上来自于百度翻译 以下为原文 You started with a very old chip. The PIC18F4620 came out in 2004, and the last update to its datasheet was in 2008, No, there is no tutorial, and it would be far simpler to just write your own code from scratch than to modify MCC to handle a new device. |
5368 浏览 9 评论
2100 浏览 8 评论
2004 浏览 10 评论
3277 浏览 3 评论
2312 浏览 5 评论
879浏览 1评论
767浏览 1评论
706浏览 1评论
764浏览 0评论
653浏览 0评论
GMT+8, 2025-3-6 02:28 , Processed in 1.026101 second(s), Total 46, Slave 41 queries .
