公司之前的demo板,基于DM368 + 海力士128M DDR + 三星128M Flash + TVP5150 AD解码器;
公司自己做的板子, 基于DM368 + 镁光256M DDR + 256M Flash + TVP5158 AD解码器; UBL、u-boot中相关DDR的代码已经根据镁光256M DDR作了调整,内核和文件系统还有应用,先不作更改放到板子上,测试系统,后续的驱动、应用等再更改。目前系统启动后出现如下问题: ======Run application sctrip file===== =====cd /dm368/===== CMEMK module: built on Mar 24 2011 at 19:34:57 Reference Linux version 2.6.32 File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c allocated heap buffer 0xc8000000 of size 0x4400000 heap fallback enabled - will try heap if pool buffer is not available CMEM Range Overlaps Kernel Physical - allowing overlap CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83c00000) cmemk initialized IRQK module: built on Mar 24 2011 at 19:35:11 Reference Linux version 2.6.32 File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c irqk initialized EDMAK module: built on Mar 24 2011 at 19:35:06 Reference Linux version 2.6.32 File /sdk/build/DVSDK_4_02/4_02_00_06/arago-install/arago-tmp/work/dm365-evm-none-linux-gnueabi/ti-linuxutils-1_2_26_01_02-r52d/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c =====run app===== cksic login: Mount TF Card OK! (/dev/mmcblk0p1) insmod: can't insert 'cmemk.ko': File exists insmod: can't insert 'irqk.ko': File exists insmod: can't insert 'edmak.ko': File exists insmod: can't insert 'dm365mmap.ko': File exists Encode demo started. CMEM Error: init: Failed to open /dev/cmem: 'No such device' CMEM Error: init: Failed to open /dev/cmem: 'No such device' CMEM Error: CMEM file descriptor -1 (failed 'open()'), ensure CMEMK kernel module cmemk.ko has been installed with 'insmod'CMEM Error: CMEM file descriptor -1 (failed 'open()'), ensure CMEMK kernel module cmemk.ko has been installed with 'insmod'CMEM Error: CMEM file descriptor -1 (failed 'open()'), ensure CMEMK kernel module cmemk.ko has been installed with 'insmod'Failed to allocate memory. Error: Failed to create buftab Error: Failed to create video encoder: h264enc 可以看到cmem分配了 (0x80000000 -> 0x83c00000)60M的空间,并初始化成功。后面挂载内核模块的时候出错: insmod: can't insert 'cmemk.ko': File exists insmod: can't insert 'irqk.ko': File exists insmod: can't insert 'edmak.ko': File exists insmod: can't insert 'dm365mmap.ko': File exists 因挂载cmemk.ko模块失败,导致后面打开/dev/cmem设备失败。 想请教下,DDR大小更改后,上面四个模块为什么挂载失败?是不是因为内存大小更改后,需要重新配置cmem模块? |
6 个讨论
物是人非aaa 发表于 2019-2-21 15:47 孟工: 您好! 我是基于DVSDK_DM365_4_02_00_06开发。 使用新的DDR配置UBL,uboot中,我针对DDR的配置的修改有: DVSDK目录/psp/u-boot-2010.12/include/configs/davinci_dm365evm.h中, CONFIG_NR_DRAM_BANKS为8; PHYS_SDRAM_1_SIZE为256M; CONFIG_MAX_RAM_BANK_SIZE为32M; 同时,把psp/u-boot-2010.12/board/davinci/common/misc.c中dram_init_banksize()函数和psp/u-boot-2010.12/arch/arm/lib/board.c中的__dram_init_banksize()函数,根据RAM大小和BANK数初始化。 内核从demo移植到kernel未作更改。是否UBL DDR更改后,内核中也要做相应的更改? 如上图,因为cmemk.ko没有正常insmod成功,基于cmem的应用层的代码也是无法启动的。 |
物是人非aaa 发表于 2019-2-21 16:28 孟工: 您好! 您说的“使用新的DDR配置的UBL,但uboot/uImage/文件系统都使用原来的,应用软件是否能正常运行?”这样的问题,我没有尝试。 以下的一条关于cmem的链接: http://wenku.baidu.com/link?url=xziKKqZKAlUR2kiwzY6-kVk51n3hVGmRy1qb***lVS-xsqWhZR1krKghTj0W6FVZTBFPImZBb_-t9W43KXRcGwAQ-rk5hSVLJpV1eMap3JHy 新板子更换DDR,我除了修改UBL代码,uboot中针对DDR的代码也做如上第三条回复的更改。内核、文件系统及相关视频编解码应用未作更改,直接移植到新板子。 内核、文件系统可以正常启动,别的应用程序也正常,但是在系统进入文件系统,执行/etc/init.d/开机自启动脚本中的挂载cmemk.ko模块时出错,导致一楼出现的错误,从而导致依赖于cmem的视频相关程序不能运行。除了这个错误,板子是能够进入Linux命令行并操作的。 |
芯片代理商 发表于 2019-2-21 16:38 你好, 您说的“使用新的DDR配置的UBL,但uboot/uImage/文件系统都使用原来的,应用软件是否能正常运行?”这样的问题,我没有尝试。 【Chris】你能尝试一下么? 较新版本的IPNC软件,里面cmem的配置都是在uboot里面配置的。我想dvsdk应该也是类似的。请问你的uboot bootargs是如何配置的?是否有修改。 你修改过的uboot起来后,能否打印识别到256MB DDR?我认为DDR扩大后只要修改uboot bootargs的配置,包括MEM,cmem的配置,kernel和文件系统应该不需要修改的。 |
483 浏览 1 评论
1024 浏览 0 评论
612 浏览 1 评论
458 浏览 1 评论
651 浏览 2 评论
244浏览 29评论
1211浏览 23评论
350浏览 20评论
324浏览 14评论
183浏览 13评论
GMT+8, 2025-2-25 08:42 , Processed in 1.134232 second(s), Total 64, Slave 54 queries .
