请参阅本文末尾的错误消息...
许可证管理器似乎使用Windows HOMEDRIVE选择放置许可证的.Xilinx文件夹的放置位置。 昨天,当我的笔记本电脑连接到Windows域控制器时,我安装了ISE WebPack 14.2。 连接到该域控制器时,我的HOMEDRIVE设置为可在该站点访问的网络驱动器号(P :)。 我今天在不同的位置,我无法访问该网络驱动器。 尽管许多尝试再次安装许可证(所有这些都报告“成功”),ISE仍然报告此错误,可能是因为它无法找到P:驱动器。 我已经和IT人员谈过了,他们拒绝改变域控制器的HOMEDRIVE策略。 如何更改许可证搜索路径,以便它将使用我的硬盘驱动器而不是网络驱动器? 我是否需要在与域控制器断开连接时重新安装WebPACK才能解决此问题? 错误信息如下: 错误:安全性:9c - 没有'ISE'或'WebPack'功能版本2012.07可用于部件'xc3s200a'.-------------------------- --------------------------------------------不存在这样的特征。特征 :WebPackLicense路径:P:/。Xilinx; C: Xilinx 14.2 ISE_DS ISE / coregen / core_licenses Xilinx.lic; C: Xilinx 14.2 ISE_DS ISE / coregen / core_licenses XilinxFree.lic; C: Xilinx 14.2 ISE_DS EDK / data / core_licenses Xilinx.lic; FLEXnet Licensing错误:-5,357。 系统错误:2“”有关详细信息,请参阅“www.acresso.com”上提供的FLEXnet Licensing文档。不存在此类功能。功能:ISELicense路径:P:/。Xilinx; C: Xilinx 14.2 ISE_DS ISE / coregen / core_licenses Xilinx.lic; C:赛灵思 14.2 ISE_DS ISE / coregen / core_licenses XilinxFree.lic; C:赛灵思 14.2 ISE_DS EDK /数据/ core_licenses 赛灵思。 lic; FLEXnet Licensing错误:-5,357有关详细信息,请参阅“www.acresso.com”上提供的FLEXnet Licensing文档。^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ERROR :Map:258 - 尝试获取此体系结构的许可证时遇到问题。 以上来自于谷歌翻译 以下为原文 Please refere to the error message at the end of this post... The license manager appears to use the Windows HOMEDRIVE in choosing where to place the .Xilinx folder holding my licenses. Yesterday, I installed ISE WebPack 14.2 while my laptop was connected to a Windows domain controller. While connected to that domain controller, my HOMEDRIVE was set to a network drive letter (P:) which was accessible at that site. I am at a different location today, I don't have access to that network drive. Despite many attempts to install the license again (all of them reported "successful"), ISE still reports this error, presumably because it fails to find the P: drive. I've already talked to the IT guys, and they declined to change the HOMEDRIVE policy of the domain controller. How do I change the license search path so that it will use my hard drive instead of a network drive? Do I need to reinstall WebPACK while disconnected from the domain controller to fix this? Error message follows: ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2012.07 was available for part 'xc3s200a'. ---------------------------------------------------------------------- No such feature exists. Feature: WebPack License path: P:/.Xilinx;C:Xilinx14.2ISE_DSISE/coregen/core_licensesXilinx.lic;C:Xilinx 14.2ISE_DSISE/coregen/core_licensesXilinxFree.lic;C:Xilinx14.2ISE_DSEDK /data/core_licensesXilinx.lic; FLEXnet Licensing error:-5,357. System Error: 2 "" For further information, refer to the FLEXnet Licensing documentation, available at "www.acresso.com".No such feature exists. Feature: ISE License path: P:/.Xilinx;C:Xilinx14.2ISE_DSISE/coregen/core_licensesXilinx.lic;C:Xilinx 14.2ISE_DSISE/coregen/core_licensesXilinxFree.lic;C:Xilinx14.2ISE_DSEDK /data/core_licensesXilinx.lic; FLEXnet Licensing error:-5,357 For further information, refer to the FLEXnet Licensing documentation, available at "www.acresso.com". ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture. |
嗨,
您可以使用LM_LICENSE_FILE环境变量更新许可证位置。 http://www.xilinx.com/support/answers/38293.htm Xilinx许可解决方案中心也是一个值得一试的好地方。 问候, 伟 以上来自于谷歌翻译 以下为原文 Hi, You can update your license location with LM_LICENSE_FILE environment variable. http://www.xilinx.com/support/answers/38293.htm Xilinx licensing solution center is a good place to check out as well. Regards, Wei |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1384浏览 1评论
596浏览 1评论
461浏览 1评论
2014浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 15:50 , Processed in 1.232637 second(s), Total 80, Slave 64 queries .
