嗨,AllI已经用PIC32 MX ETS启动工具包开发了一个项目,现在它已经过时了,我想切换到2版。在和谐中,我改变了PHY引用和BSP类型,我编译我的项目没有错误,但是当编程时,我有这个错误:有人能帮忙吗?谢谢
以上来自于百度翻译 以下为原文 Hi All I have devlopped a project using PIC32MX Eth Starter kit, and now as it's obsolete, I want to switch to version 2. In HARMony, I changed the PHY reference and BSP type, I compile my project without error but when programming, I have this error: Connecting to Starter Kit on Board... Currently loaded firmware on Starter Kit on Board Firmware Suite Version.....00.00.00 * Firmware type..............Unknown Firmware Type Now Downloading new Firmware for target device: PIC32MX795F512L Downloading RS... RS download complete Programming download... Connection Failed. can someone help please? thanks |
9个回答
嗨,我已经使用这个工具包上周,并设法连接到MPLAB X V3.65.MPLAX版本你有没有?哪些Windows版本?你的连接问题与和声变化无关。这是一个纯粹的USB枚举/连接的工具,最近我也看到PIC32启动工具包有时会有更新固件的困难。我总是安装2个不同的MPLAB X版本,以便能够启动2个实例来解决这个问题。它的另一个MPLAB X版本,使它重新启动固件更新从一开始。我个人的分析是,初学者工具包是非常敏感的USB电压(VBUS)。如果PC USB VBUS有点低,它们很难正确地连接/更新。有时我尝试移动到另一个USB端口。最后我总是管理,但它需要几次试验…
以上来自于百度翻译 以下为原文 Hi, I have used this kit last week and managed to connect to MPLAB X v3.65. Which MPLAB X version do you have ? Which Windows version ? Your connection issue is not related to Harmony changes. It is a pure issue of USB enumeration / connection with the tool I have also seen recently that PIC32 starter kits have sometimes difficulties to update firmware. I always have 2 different MPLAB X versions installed to be able to launch 2 instances To solve this issue I generally connect the starter kit to the other MPLAB X version so that it restart the firmware update from the beginning. My personal analysis is that starter kits are very sensitive to the USB voltage (Vbus). If the PC USB Vbus is a little low they have difficulty to properly connect / update. I sometimes try to move to another USB port. Finally I always managed but it takes a few trials... Regards |
嗨,谢谢你的回复。我在Wi7和MPLAB X V3.55.i当我编程“ETS初学者工具包”是可以的,但是当我尝试编程“ETS启动器套件2”失败时,我尝试了所有可用的USB端口。
以上来自于百度翻译 以下为原文 Hi and thanks for reply. I am on Win7 and MPLAB X V3.55. when I programm "Eth starter kit" is ok, but when I try to program "Eth starter kit 2" it fails. I tried all available USB ports. |
您好,我想问题是这个起动器套件的功耗是高的,因为PHY板您可以尝试以下:1 /电源关闭(删除USB电缆)2 /非常小心地删除包含RJ45连接器的小夹层板(想法是降低PIC的功耗32以太网启动器套件II)3 /后退USB电缆4 /尝试从MPLAB X编程。希望它能管理更新启动器KIT上的固件5/如果这工作,删除USB电缆并将夹层板放回去。希望现在可以编程和调试;=)如果它不工作,我建议。你安装MPLAB X V3.65(你可以保持V3.55,因为它将在另一个目录)。然后从MPLAB X V3.65重新启动以上过程
以上来自于百度翻译 以下为原文 Hi, I think the issue is the power consumption of this starter kit is high due to the PHY board Can you please try the following : 1/ Power off (remove USB cable) 2/ Remove very carefully the small mezzanine board which contains the RJ45 connector (the idea is to reduce the power consumption of the PIC32 ethernet starter kit II) 3/ Plug back the USB cable 4/ Try to program from MPLAB X. Hopefully it will manage to update the firmware on the starter kit. 5/ If this works, remove the USB cable and put back the mezzanine board. Hopefully now you can program and debug ;=) If it does not work, I recommend that you install MPLAB X v3.65 (you can keep v3.55 as it will be in another directory). Then restart above procedure from MPLAB X v3.65 Regards |
我刚从假期回来…我试过所有的点,但仍然有问题。我还订购了新的演示板,同样的问题。我试着使用MPLAB IPE,同样的错误信息。唯一为我工作的板是版本1。我不知道第1版和第2版有什么不同,除了ETH!有什么想法吗?谢谢!
以上来自于百度翻译 以下为原文 Hi RISC just returning from holiday... I tried all points but still having problem. I also ordered new demo board, same issue. I tried to use Mplab IPE, same error message. the only board working for me is version 1. I don't know what is differences between version 1 and 2 except ETH! Any idea? thanks! |
嗨,今天我再次尝试了PIC32以太网启动器套件II,并看到与您相同的问题(我猜)“连接失败”都在MPLAB X V3.65和MPLAB X V4.00上和声V2.03BiTimi我的板被连接到一个USB端口在我的PC的坞站。然后我直接连接到一个。我的笔记本电脑的USB端口和固件的更新发生了,和声项目被正确地闪亮了(PIC32页EthyWebServer在和谐V2.03B)。我没有删除夹层板,所以我只能建议你移动你的USB电缆到不同的USB端口在你的PC上,看看这是否有帮助。我猜是VBUS输出电压的USB集线器(内部PC)不同,启动器套件似乎是非常敏感的……主要的区别是以太网启动套件1和2是调试端口。SK1(JTAG)在调试PIC和应用程序PIC之间是非标准的,它是在所有起始包上存在的SK2上的PKOB(PIKIT),因此应该是更好的:=(Encess SPS:只是注意到似乎和声V2.04不再支持PIC32以太网SK1或2)。
以上来自于百度翻译 以下为原文 Hi, I tried again today with PIC32 ethernet starter kit II and saw the same issue as you (I guess) "connection failed" both on MPLAB X v3.65 & MPLAB X v4.00 with Harmony v2.03b Initially my board was connected to one USB port on the docking station of my PC. Then I made a direct connection to one USB port of my laptop and the update of the firmware took place and the Harmony project was flashed correctly (pic32_eth_web_server in Harmony v2.03b). I did not remove the mezzanine board. So I can only recommend that you move your USB cable to different USB ports on your PC and see if this helps. My guess is that the Vbus output voltage of USB hubs (inside PC) differs and the starter kit seems to be very sensitive to this... The major difference between ethernet Starter kit 1 and 2 is the debug port. It is non standard on SK1 (JTAG) between debug PIC and application PIC) and it is the PKOB (Pickit On Board) on SK2 which exist on all starter kits so it should be better :=( Regards PS : just noticed that it seems Harmony v2.04 does not support anymore PIC32 ethernet SK1 or 2 |
我使用了另一台计算机和MPLAB IPE,主板的固件是0 .00 .00。在连接之后,它变成了01.5 0.24,然后我用我的笔记本电脑尝试了最初失败的编程,但是现在它正在顺利地编程。谢谢您的帮助!!!!
以上来自于百度翻译 以下为原文 Hi problem resolved. I used another computer and Mplab IPE, the firmware of board was 00.00.00 before and then after connection, it became 01.50.24 then I tried with my laptop that initially failed programmation, but now it is succefully programming. thank you for help!!! |
来到这里也有类似的问题。这里是我的解决方案:我使用PIC32 ETS启动器套件II没有问题。然后,我迁移到一个新的计算机,全新的MPLABX V4.01安装,第一次超时编程得到了相同的连接失败,这里报道。尝试了几次,打开电源,重新启动,所有的运气都没有运气。我使用USB主机模式,所以我有跳过J5。绝对是一个电源问题,我在J5上移除了跳线,问题就消失了。我把跳线放在J5上,我仍然很好的编程。
以上来自于百度翻译 以下为原文 Came here with a similar problem. Here's my solution: I am using PIC32 Eth Starter Kit II with no problem. Then I migrated to a new computer, brand new MPLABX v4.01 installation, and first time out programming got the same Connection Failed reported here. Tried it several times, power on off, reboot, all the usual suspects with no luck. I am using the USB Host mode so I have jumpered J5. Definitely a power issue, I removed the jumper on J5 and the problem went away. I put the jumper back on J5 and am still programming fine. |
我和MZEF STK有同样的问题,它在我的MacBook中完美无瑕,但在Wi10下我也会犯同样的错误。SMAS MPLAB X 3.65
以上来自于百度翻译 以下为原文 I have the same issue with the MZEF STK, it works flawlessly in my MacBook but gives me the same error under win10. Ssame MPLAB X 3.65 |
我发现如何修复它,进入设备管理器窗口并在HID组内找到启动工具包,找到带有微芯片VID的一个,即0x04D8,然后右击选择“更新驱动程序”选项,然后需要浏览本地存储的驱动程序(默认的Windows一个)重新安装它,然后重新启动,你就可以工作了!
以上来自于百度翻译 以下为原文 I found out how to fix it, go into the device manager window and find the starter kit inside the HID group, find the one with the microchip VID which is: 0x04D8 and right click to select the "update driver" option, then you need to browse for a locally stored driver (a default windows one) and just reinstall it, then reboot and you're ready to work! |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
486浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-21 02:43 , Processed in 1.052524 second(s), Total 58, Slave 53 queries .
