你好,
我有2个GPIF配置我想使用一个应用程序。第一个GPIF配置只使用16位使SPI外围是可用的。然而第二2 GPIF配置我的变化通过调用cyu3pgpifdisable(cytrue);和cyu3pgpifload()进入一个奇怪的模式,它记录了32位数据DMA缓冲区但是前16位是等价的低16位。如果我循环加载16bit GPIF配置直走到32位配置一切都好。 当我cyu3pdeviceconfigureiomatrix()初始化设备,isdq32bit设置为true。有什么办法可以切换isdq32bit当我改变2 GPIF配置之间的不同吗?我问你的原因是因为这是我的理解,cyu3pdeviceconfigureiomatrix()只能调用一次。 谢谢你 以上来自于百度翻译 以下为原文 Hello, I have 2 GPIF configurations I'd like to use in an application. The first GPIF configuration only uses 16 bits so that the SPI peripheral is available. However the second 2 GPIF configuration that I change to by calling CyU3PGpifDisable(CyTrue); and CyU3PGpifLoad() enters a weird mode where it does record 32 bits of data to DMA buffers however the top 16 bits are equivalent to the lower 16 bits. If I bypass loading the 16bit GPIF config and go straight to the 32bit config everything is fine. When I initialize the device with CyU3PDeviceConfigureIOMatrix(), isDQ32Bit is set to true. Is there any way to toggle isDQ32Bit when I change between the 2 different GPIF configurations? The reason I ask is because it is my understanding that CyU3PDeviceConfigureIOMatrix() can only be called once. Thank you |
嗨,维维纳玛,
你可以打电话给IoMatrix…不止一次。这是必要的切换之间的16 / 32位模式的GPIF接口,还激活/去激活外围SPI接口。那东西已经在这个论坛上讨论,看看以下职位… HTTP://www. CyPress?COM/?APP =论坛和ID ID=167和;RID=58084 当做, 隆皮 以上来自于百度翻译 以下为原文 Hi Vivenoma, you can call IoMatrix... more than one time. That is necessary to switch between 16-/32-bit Mode of GPIF interface and also to activate/deactivate the peripheral SPI interface. That stuff is already discussed in this forum, see following post.... http://www.cypress.com/?app=forum&id=167&rID=58084 regards, lumpi |
741个成员聚集在这个小组
加入小组2004 浏览 1 评论
1763 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
277浏览 2评论
171浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-21 19:31 , Processed in 0.785190 second(s), Total 76, Slave 60 queries .
