美好的一天!
我想知道如何在FPGA上有持久的价值,我的意思是当我修改它的值时,当块再次运行时,值不会被改变? 在matlab中通过定义一个像:persistent u的值,它会完成,但VHDL怎么样, 我怎样才能使它合成。 谢谢大家! 以上来自于谷歌翻译 以下为原文 Good Day! I would like to know how can I have a persistent value on FPGA,I mean when I modified its value,when the block run again the value would not be changed ? In Matlab by defining a value like : persistent u,it would be done,but how about VHDL, and how can I make it synthesisable. Thanks All! |
嗨,
基本上这是一个信号。 但持久并不意味着价值无法修改。 它只保留函数最后一次运行的值。 (也许这取决于你在matlab中定义持久变量的位置。 全局或功能内部。) 与变量相比,VHDL中的信号也是如此。 如果这不是你想要的, 也许您可以给出一个显示所需行为的matlab示例。 有一个很好的综合 Eilert 以上来自于谷歌翻译 以下为原文 Hi, basically that's a signal. But persistent does not mean that the value can not be modified. It just keeps the value from the last run of the function. (Maybe it depends on where you define the persistent variable in matlab. globally or inside a function.) That's what in VHDL a signal does as well, compared to variables. If this is not what you were looking for, Maybe you can give a little matlab example that shows the desired behavior. Have a nice synthesis Eilert |
2500 浏览 7 评论
2871 浏览 4 评论
2330 浏览 9 评论
3424 浏览 0 评论
2512 浏览 15 评论
2455浏览 1评论
660浏览 1评论
521浏览 1评论
801浏览 0评论
GMT+8, 2025-2-24 20:48 , Processed in 1.287572 second(s), Total 74, Slave 58 queries .
