扫一扫,分享给好友
函数原型 FlashResult Start ( VFLASHHANDLE projectHandle, CallbackProgress callbackProgress, CallbackStatus callbackStatus ) 函数说明 Parameters: [in] projectHandle Handle to the project [in] callbackProgress Function pointer periodically reporting the flash progress in percent and the remaining time in [sec] [in] callbackStatus Function pointer reporting the status of the flash process. The flash process is completed, either if "FS_Success" or an error ("FS_xxx > 0") is signaled Returns VFlashResult Error or success information。 回调函数一 typedef void(* CallbackProgress)(unsigned int progressInPercent, unsigned int remainingTimeInS); 函数说明 Returns VFlashResult Error or sucallback reporting the flash progress in percent and the remaining time in [sec]. Parameters [in] progressInPercent Flash progress in percent [in] remainingTimeInS Remaining time in [sec] 回调函数二 typedef void(* CallbackStatus)(VFlashStatus flashStatus); 函数说明 Callback reporting the status of the flash process. The flash process is completed, either if "FS_Success" or an error ("FS_xxx > 0") is signaled. Parameters [in] flashStatus The flash status C语言中回调函数一和二,直接打印输出 void ReportProgress(unsigned int progressInPercent, unsigned int remainingTimeInS) { printf("Progress: %d%% - Remaining Time: %2d secsr", progressInPercent, remainingTimeInS); } void ReportStatus(VFlashStatus flashStatus) { if (flashStatus == FS_Success) { printf("nReprogramming successfully finished.nn"); } else { printf("nReprogramming failed (Code: %d)nn", flashStatus); PrintLastFlashError(false); } } 请问回调函数一中的参数值progressInPercent, remainingTimeInS,回调函数二中的参数值flashStatus,怎么在labview中作为输出值显示? dll及头文件见附件,请大神们帮帮忙,万分感谢!
1 条评论
3个回答
可以用调用库函数节点 选择 互联接口---库于可执行程序---调用库函数节点,然后双击调用库函数节点,配置库函数调用的deLL文件路径设置一下就好了
大佬,解决了吗,我也需要用labview去调用这个vFLASH,,请问这个怎么解决?跪求!
部署计算机上运行 LabVIEW 应用程序时出现以下错误: “缺少外部函数 dll...”解决办法
817 浏览 0 评论
984 浏览 1 评论
3332 浏览 3 评论
3057 浏览 1 评论
NI USB-6008/6009双通道AO输出及AI输入显示
2692 浏览 0 评论
GMT+8, 2025-4-17 04:55 , Processed in 0.453548 second(s), Total 53, Slave 44 queries .
