我正在尝试使用CDC21COMLPORtiON单实例,为我自己的PIC32 MX470硬件与USB启动器套件3板。构建成功,现在当我尝试使用PICTIT3将程序上传到我的PIC32 MX470时,我得到以下错误:“目标设备ID(0x58FF053)是一个有效的设备ID,但与所选的设备ID(0x580B053)不匹配。”我如何解决这个问题?正如我所理解的,我正在使用的BSP配置已经将设备ID设置为0x580B053。我怎样才能改变这个?
以上来自于百度翻译 以下为原文 I am trying to use the cdc_com_port_single example with the u*** starter kit 3 board for my own PIC32MX470 hardware. the build is successful and now when i try to upload the program to my PIC32MX470 using PICKIT3 I get the following error: "Target Device ID (0x58ff053) is a valid Device ID but does not match the expected Device ID (0x580b053) as selected." how can i solve this problem? as I understand, the BSP configuration that I am using has set the Device ID to be 0x580b053. How can i change this? |
3个回答
这个问题已经解决了,对于任何有相同问题的人来说,我的问题都与电源有关。但是电源ID与设备ID有什么关系呢?信息。我认为这很有误导性。
以上来自于百度翻译 以下为原文 the problem is solved. For anyone who share the same problem, mine had to do with power supply. but what the heck has power supply to do with device ID? the info. is quite misleading, I think. |
嗨,仔细阅读留言:上面写的PIC不是你在项目中选择的PIC…每个字母计数…如果项目是PIC32 MZ2048 EFM144,那么如果你连接APIC32 MZ2048 EFH144,它告诉你它不匹配…
以上来自于百度翻译 以下为原文 Hi, "Target Device ID (0x58ff053) is a valid Device ID but does not match the expected Device ID (0x580b053) as selected." Read the message carefully : it says that the PIC on the board is not the PIC you have selected in the project... Each letter counts....if the project is for PIC32MZ2048EFM144 then if you connect a PIC32MZ2048EFH144, it tells you it does not match... Regards |
iSpPc58XX053部分是硬连线的,而“XX”则是在启动时从某种内部固件加载的。这也发生在我身上,但在我的情况下,我移动得太快了。在得到ID之前插入一个小的延迟解决了这个问题。
以上来自于百度翻译 以下为原文 I suspect the 58xx053 part is hardwired, while the "xx" is loaded from some sort of internal firmware on startup. This happened to me too, but in my case I was moving too fast. Inserting a small delay before getting the id solved the problem. |
5060 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3100 浏览 3 评论
2174 浏览 5 评论
613浏览 1评论
484浏览 1评论
343浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 09:37 , Processed in 0.907276 second(s), Total 46, Slave 41 queries .
