对于工业化进程,我需要改变特定PIC16F1705地址的内容。是否有一些特定的工具来实现这种内存更改,或者我需要直接更改“No.HEX”文件(问题以很好地选择好的内存地址)。谢谢您的反馈。
以上来自于百度翻译 以下为原文 For industrialization process, I need to change the content of specific PIC16F1705 addresses. Are there some specific tools to implement this memory changes or do I need to directly change the "name.hex" file (problem to well select the good memory addresses). Thanks for your feedback |
4个回答
IPE可以做到这一点,但它是劳动密集型的。如果你试图序列化部件,那么IPE可以自动完成。另外,我认为如果你想自己编写它,就有API来控制程序员。
以上来自于百度翻译 以下为原文 IPE can do it but it is labor intensive. If you are trying to serialize parts then IPE can do it automaticly. Additionally the I think there are APIs available to control the programmer if you want to write it your self. |
嗨,我相信最简单的方法是在高级模式中使用MPLAB IPE。IPE是MPLAB X软件包的一部分。一旦你改变了高级模式中的参数并输出新的HEX文件,你就应该能够编辑内存位置。如果你直接拨动内存,就非常非常小心。它将是ToTa。与源代码代码比较
以上来自于百度翻译 以下为原文 Hi, The easiest way I belive is to use MPLAB IPE in advanced mode. IPE is part of MPLAB X software package. You should be able to edit the memory locations once you changed the parameters in advanced mode and export the new HEX files. If you poke directly memory, be very very careful....It will be totally undocumented compared to the source code Regards |
谢谢你的回复。MPLAB IPE是一个很好的工具,用于少量文件的改变,但不是大规模生产。我认为最好的是在十六进制文件中改变数据存储器在正确的地址。然而,在MPLAB X仪表板上,我有一个关于CRC值的问题,即使改变代码,CRC计算也是一样的。有人对这个问题有想法吗?
以上来自于百度翻译 以下为原文 Thanks for reply. MPLAB IPE is a good tool for small number of file to change but not for mass production. I think the best is to direclty change in the .hex file the data memory at the right addresses. However I have a question regarding the CRC value in the MPLAB X Dashboard, the CRC calculation is always the same even if I change the code. Does anyone has an idea on that issue ? |
嗨,如果你需要一个工具来自动化更改,那么你应该使用MPLAB X SDK或MbCys:http://www. opsSunCux4pic…PLAB-X-SDK-MPLAB-X-IDEU可以编写一个应用程序,它将调用MbCype并使用一些脚本来自动更改所需的更改。
以上来自于百度翻译 以下为原文 Hi, If you need a tool to automate changes then you should use the the MPLAB X SDK or MDBcore : http://www.opensource4pic...plab-x-sdk-mplab-x-ide you can write an application which will call into MDBcore and automate the changes you need using some scripting Regards |
5244 浏览 9 评论
2035 浏览 8 评论
1955 浏览 10 评论
3214 浏览 3 评论
2261 浏览 5 评论
781浏览 1评论
676浏览 1评论
602浏览 1评论
684浏览 0评论
581浏览 0评论
GMT+8, 2024-12-26 11:15 , Processed in 1.344859 second(s), Total 84, Slave 68 queries .
