TABLE 7管脚定义中给出了使用方法。就是看/RE和DE管脚的电平。
RE Receiver Output Enable. A low level enables the receiver output, RO. A high level places it in a high impedance state. If RE is high and DE is low, the device enters a low power shutdown mode. DE Driver Output Enable. A high level enables the driver differential Output A and Output B. A low level places it in a high impedance state. If RE is high and DE is low, the device enters a low power shutdown mode. 可以将RE和DE管脚连接到MCU的GPIO引脚,通过控制拉高拉低来使能接收和发送。 |
2242个成员聚集在这个小组
加入小组ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1776 浏览 1 评论
4155 浏览 2 评论
8869 浏览 1 评论
3073 浏览 1 评论
7059 浏览 2 评论
1227浏览 3评论
1536浏览 2评论
1470浏览 2评论
1241浏览 1评论
1068浏览 1评论
GMT+8, 2024-9-21 08:12 , Processed in 0.799984 second(s), Total 44, Slave 39 queries .
