嗨,
是否提供Linux版Xilinx Documentation Navigator? 如果没有,当前的Windows版本在Wine下运行良好吗? 谢谢 以上来自于谷歌翻译 以下为原文 Hi, Is the a Linux version of Xilinx Documentation Navigator available? If not, does current windows version work fine under Wine? Thanks |
3个回答
Document Navigator下载包括Windows和Linux版本。
http://www.xilinx.com/support/download/index.htm ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 The Document Navigator download includes both Windows and Linux versions. http://www.xilinx.com/support/download/index.htm ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.comView solution in original post |
http://www.xilinx.com/support/download/index.htm ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 The Document Navigator download includes both Windows and Linux versions. http://www.xilinx.com/support/download/index.htm ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2306 浏览 7 评论
2716 浏览 4 评论
2197 浏览 9 评论
3278 浏览 0 评论
2351 浏览 15 评论
631浏览 1评论
1682浏览 1评论
652浏览 0评论
1839浏览 0评论
562浏览 0评论
GMT+8, 2024-9-20 08:55 , Processed in 1.149401 second(s), Total 49, Slave 44 queries .
