更新:
当我使用HSI时它可以很好地工作到30Hz当我使用HSE时,那就是我遇到问题的地方。这是我的时钟初始化,我该如何解决这个问题? CLK_DeInit(); / *根据CLK_InitStructure 24MHz * /启动时钟控制器 status = CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO,CLK_SOURCE_HSE,DISABLE,DISABLE); while(CLK_GetFlagStatus(CLK_FLAG_HSERDY)== 0); 以上来自于谷歌翻译 以下为原文 UPDATE: When I use the HSI it works fine down to like 30Hz When I use the HSE, that's where I get the problem. Here's my clock init, how can I fix this? CLK_DeInit(); /* Initilize the Clock controller according to CLK_InitStructure 24MHz */ status = CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO, CLK_SOURCE_HSE, DISABLE, DISABLE); while (CLK_GetFlagStatus(CLK_FLAG_HSERDY) == 0); |
2906 浏览 1 评论
3290 浏览 1 评论
1870 浏览 1 评论
3724 浏览 6 评论
6134 浏览 21 评论
GMT+8, 2025-3-9 10:28 , Processed in 0.707440 second(s), Total 75, Slave 59 queries .
