在Xilinx软件符号库中,AND和OR门的最大输入数为9.如果需要10输入AND和OR门,您会怎么做?
我正在使用Xilinx ISE软件,学生版V10.1 请帮忙。 以上来自于谷歌翻译 以下为原文 In the Xilinx software symbol library, the maximum number of inputs for AND and OR gates is 9. What would you do if 10-input AND and OR gates are needed? I'm using Xilinx ISE software, student edition V10.1 Please help. |
尝试将6输入AND(或OR)门的输出连接到5输入AND(或OR)门的输入。
或者跳转到VHDL或Verilog。 如果您值得花时间学习原理图捕获,那么学习硬件设计语言甚至可以花费更多时间。 应该教授电路板设计的原理图捕获,而不是FPGA或ASIC设计。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Try connect the output of a 6-input AND (or OR) gate to an input of a 5-input AND (or OR) gate. Or make the jump to VHDL or Verilog. If it's worth your time to learn schematic capture, it's even *MORE* worth your time to learn a hardware design language. Schematic capture should be taught for board design, not for FPGA or ASIC design. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
或者你可以用3关4输入门做到这一点。但是除非有一个超越理由去做原理图,例如课程要求或史前监督,否则由HDL做,正如备受尊敬的前任海报所暗示的那样。
------------------------------------------“如果它不起作用 模拟,它不会在板上工作。“ 以上来自于谷歌翻译 以下为原文 Or you could do it with 3-off 4-input gates. But unless there is an over-riding reason to do schematics, such as a course requirement or prehistoric supervisor, do it by HDL, as the highly esteemed previous poster suggests. ------------------------------------------ "If it don't work in simulation, it won't work on the board." |
2474 浏览 7 评论
2860 浏览 4 评论
2321 浏览 9 评论
3406 浏览 0 评论
2502 浏览 15 评论
2154浏览 1评论
644浏览 1评论
504浏览 1评论
2054浏览 0评论
783浏览 0评论
GMT+8, 2025-2-2 23:30 , Processed in 1.267853 second(s), Total 78, Slave 62 queries .
