你好
我在将ISE旧项目(ISE 9.1)迁移到新项目(ISE 12.3)时遇到了一些问题。 在重新生成IP核的情况下,我用12.3打开了我的旧项目,然后它只要求迁移。 我在旧项目中使用了所有IP核。(单端口RAM,FIFO,双端口RAM,分布式RAM) 我打开了该选项,我的项目正在正确实现,但在用硬件检查后给出了结果。 (在我的设计中没有改变行为)当我用9.1i打开时,这是有用的。 给我解决方案,因为我想更新这个设计wirh高密度设备(斯巴达-6)我应该使用12.3 谢谢 以上来自于谷歌翻译 以下为原文 Hi I have some problems in migrating ISE old project (ISE 9.1)to new one(ISE 12.3). With out regenerating IP cores i opened my old project with 12.3 then it asked for migration only. I used in old project all the IP cores.(single port ram, FIFOs,Dual port RAM,distributed RAM) I opened with that option my project is implementing properly but after checking with hardware its giving Result. (No behavior changed in my design) byt this is working when i open with 9.1i. Give me solution for this as i wanted to update this design wirh high density devices(spartan-6) i should work with 12.3 Thanks |
你好,
我认为如果你要使用相同的设备并且部分之间的差异很小,那么旧项目的迁移就可以了。 但是在您的情况下,版本之间有4年的时间。 由于时间已经有很多改进和错误修复您的设备的IP。 此外,如果您计划使用新设备,那么您还应该为该设备重新生成IP。 在我看来,由于这些要点,您最好的行动方案是为新设备重新创建项目,而不是尝试升级它然后更改设备。 好的,希望这有帮助...... 以上来自于谷歌翻译 以下为原文 Hello, I think that migration of an older project is fine if you are going to use the same device and the difference between the vesions is small. However in your case, there have been 4 years between versions. Because of the time there have been many improvements and bug fixes for the IP of your device. In addition, if you are planning on using a new device, then you should also expect to regenerate your IP for that device. It seems to me that because of these points, the best course of action for you is to re-create your project for the new device rather than attempt to upgrade it then change the device. OK, hope this helps ... |
2363 浏览 7 评论
2782 浏览 4 评论
2248 浏览 9 评论
3326 浏览 0 评论
2414 浏览 15 评论
734浏览 1评论
524浏览 1评论
337浏览 1评论
742浏览 0评论
1940浏览 0评论
GMT+8, 2024-11-10 16:15 , Processed in 0.952707 second(s), Total 45, Slave 40 queries .
