你好;
我正在尝试使用SPI与外部闪存(M25PE80)进行通信。我正在使用STM8SPI库,但我没有成功写入/读取内存。我的疑问是关于引脚的配置。是否有任何Option Byte我必须设置为使用SPI备用功能?我是否需要使用GPIO_Init配置用于SPI(MISO,MOSI,CLK)的端口?对于片选引脚,我使用PortG0作为GPIO_MODE_OUT_PP_LOW_FAST。 这些是我用来初始化SPI的代码(来自stm8s_spi.c的功能): SPI_DeInit(); SPI_Init(SPI_FIRSTBIT_MSB,SPI_BAUDRATEPRESCALER_64,SPI_MODE_MASTER,SPI_CLOCKPOLARITY_HIGH,SPI_CLOCKPHASE_2EDGE,SPI_DATADIRECTION_2LINES_FULLDUPLEX,SPI_NSS_SOFT,0x07); SPI_Cmd(ENABLE); 问候 以上来自于谷歌翻译 以下为原文 Hello; I'm trying to communicate to an external flash memory (M25PE80) using SPI. I´m using the STM8SPI librarie but I´m not having success to write/read from memory. My doubt is about the configuration of pins. Are there any Option Byte that I must set to use the SPI alternate function? Does I need to use the GPIO_Init to configure the ports used for SPI (MISO, MOSI, CLK)? For the Chip Select pin, I´m using the PortG0 as GPIO_MODE_OUT_PP_LOW_FAST. These are the code I´m using to init the SPI (Funtions from stm8s_spi.c): SPI_DeInit(); SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_64,SPI_MODE_MASTER,SPI_CLOCKPOLARITY_HIGH, SPI_CLOCKPHASE_2EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX,SPI_NSS_SOFT, 0x07); SPI_Cmd(ENABLE); Regards |
3个回答
问题解决了!无需配置SPI引脚。 Init Function配置所有正确的参数。
以上来自于谷歌翻译 以下为原文 Problem Solved! There is no need to configure the SPI pins. The Init Function configure all the correct parameters. |
尚未尝试SPI,但SPI_NSS引脚不应该作为芯片选择吗? (而不是在您的示例中使用GPIOG0)
以上来自于谷歌翻译 以下为原文 Haven't tried yet SPI, but isn't the SPI_NSS pin supposed to act as a chip select? (instead of using GPIOG0 in your example) |
你好尼科;
是的,作为输出引脚,您可以使用GPIOE5引脚,但考虑到在SPI通信中您可以选择与您拥有的芯片选择引脚一样多的器件,您可以为此功能配置任何I / O引脚(芯片选择)。要写入外部闪存,您需要控制设置或重置此引脚的确切时刻。其他引脚实际上是备用功能引脚。您只需在寄存器上写入,ucontroller就会为您发送/接收数据。 问候。 法比奥 以上来自于谷歌翻译 以下为原文 Hello Nico; Yes, as an output pin you could use the GPIOE5 pin, but considering that in SPI communication you can select as many devices as many chip select pins you have, you could config any I/O pin for this function (chip select). For write into the external flash memory you will need to control the exactly moment to set or reset this pin. The other pins are really alternate function pins. You just write on a register and the ucontroller transmits/receive data for you. Regards. Fabio |
2776 浏览 1 评论
3251 浏览 1 评论
1822 浏览 1 评论
3667 浏览 6 评论
6060 浏览 21 评论
1347浏览 4评论
212浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
368浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
464浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
291浏览 2评论
GMT+8, 2025-1-8 22:03 , Processed in 0.982153 second(s), Total 46, Slave 41 queries .
