嗨,
我通过IPv4连接到SPWF01,并在我的路由器中连接端口。它工作正常,只要我有一个IPv4路由器/互联网连接。当我有IPv6连接和DS-Lite时,它不起作用。那么,是否有可能更新SPWF01 for IPv6? 最好的祝福, 弗洛里安 以上来自于谷歌翻译 以下为原文 Hi, I connect to the SPWF01 via IPv4 and a port forwarding in my router. It works fine, as long I have a IPv4 router / internet connection. When I have a IPv6 connection and DS-Lite it doesn't work. So, is there a possibility to update the SPWF01 for IPv6? Best regards, Florian |
6个回答
Ciao Flow,
IPv6不是SPWF01S功能的一部分。你可以切换到SPWF04S ...... 以上来自于谷歌翻译 以下为原文 Ciao Flow, IPv6 is not part of SPWF01S features. You can switch to SPWF04S... |
嗨格里,
谢谢您的回答。 不好,我无法切换,因为生产已经开始使用SPWF01S。在设计阶段,SPWF04不可用...... 那么,有没有计划在SPWF01中添加IPv6? 干杯, 流 以上来自于谷歌翻译 以下为原文 Hi Gerry, thank you for your answer. Poorly, I can't switch because the production already started with the SPWF01S. In the design phase, the SPWF04 wasn't available... So, there are no plans adding IPv6 to the SPWF01? Cheers, Flow |
我不这么认为。
Flash几乎已满,RAM有限,内部的LWIP版本不支持IPv4 + 6,SPWF04已经上市等等...... 以上来自于谷歌翻译 以下为原文 I don't think so. Flash is almost full, RAM is limited, LWIP version inside is not supporting IPv4+6, SPWF04 already on the market, etc... |
好的,那么我将看看如何更换SPWF01与SPWF04 ....
以上来自于谷歌翻译 以下为原文 Ok, then I will look how to replace the SPWF01 against the SPWF04.... |
从HW的角度来看,它们是引脚到引脚兼容的。此外,由于SPWF04S的GPIO高电平至3V3,因此不再需要TTL到MCU。
从AT命令的角度来看,它们是90%兼容的。 SPWF04S始终使用BNF来简化MCU管理(不再需要命令/数据模式): - AT + S.在命令上 - AT-S。同步事件 - 异步事件中的+ WIND:number:message [:param [:params ...]] BR Ĵ 以上来自于谷歌翻译 以下为原文 From HW point of view, they are pin to pin compatible. Moreover, since SPWF04S has GPIOs high level to 3V3, TTL to MCU is no more needed. From AT-commands point of view, they are 90% compatible. SPWF04S always uses a BNF to simplify MCU management (no more command/data mode): - AT+S. on commands - AT-S. on sync events - +WIND:number:message[:param[:params...]] on async events BR j |
嗨,杰里,
感谢您提供更多信息 - 听起来不错。 问候, 流 以上来自于谷歌翻译 以下为原文 Hi Jerry, thank you for the further information - sounds good. Regards, Flow |
3016 浏览 1 评论
3332 浏览 1 评论
1913 浏览 1 评论
3772 浏览 6 评论
6194 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
81浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
94浏览 5评论
120浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
84浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
90浏览 5评论
GMT+8, 2025-4-25 19:26 , Processed in 0.621998 second(s), Total 54, Slave 48 queries .
