美好的一天!
我正在尝试将寄存器值分配给COSMIC C中的变量。我先尝试了一种显而易见的方法,但它不起作用: uint8_t test = 0; ... test = CLK-> SWCR; //从stm8s.h定义 和 uint8_t test = 0; ... test = CLK_SWCR; //从''C: Program Files COSMIC CXSTM8_32K Hstm8 iostm8s.h'中定义 当我在调试模式下运行程序并为'test'变量创建监视时,它始终为零。 有什么不对? 提前致谢! 以上来自于谷歌翻译 以下为原文 Good day! I'm trying to assign register value to a variable in COSMIC C. I've tried the obvious way first, but it doesn't work: uint8_t test = 0; ... test = CLK->SWCR; // define from stm8s.h and uint8_t test = 0; ... test = CLK_SWCR; // define from ''C:Program FilesCOSMICCXSTM8_32KHstm8iostm8s.h'' When I run my program in Debug mode and create a watch for 'test' variable it is always zero. What can be wrong? Thanks in advance! |
嗨,
一种可能性是你的变量''test''被优化掉了:将volatile作为最小值声明。 还要检查您正在读取的硬件寄存器实际上是否包含零。 希望能帮助到你。 卢卡 以上来自于谷歌翻译 以下为原文 Hi, one possibility is that your variable ''test'' is optimized away: declare it volatile as a minimum. Also check that the hardware register you are reading does not actually contain zero. Hope it helps. Luca |
2747 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
449浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
276浏览 2评论
GMT+8, 2024-12-28 21:45 , Processed in 0.887435 second(s), Total 45, Slave 40 queries .
