我正面临Infiniium示波器(DSO 81304)和有源探头(2795A)的问题。
示波器不会加载探头编号或以任何方式识别它。 大多数情况下它会显示“读取错误”。 我已经验证了范围与其他探测器的功能是否正确。你们可以建议解决这个问题吗? 以上来自于谷歌翻译 以下为原文 I'm facing an issue with an Infiniium oscilloscope (DSO 81304) and an active probe (2795A). The scope doesn't load up the probe number or recognize it in any way. Most of the time it displays a 'read error'. I have verified that the scope functions correctly with other probes.Could you guys suggest a solution to this problem? |
3个回答
请重新阅读范围部件号。
它可能是N2795A 1GHz有源探头。 80000系列示波器于2006年停产,支持终止于2011年。最后一次转发发布于2009年初.N2795A于2010年底发布,范围SW绝对无法识别。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦威廉希尔官方网站 呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 Please reread the scope part number. It's probably an N2795A 1GHz Active probe. The 80000 series of scopes was discontinued in 2006, and the end of support was 2011. The last SW release was in early 2009. The N2795A was released in late 2010, and the scope SW definitely won't recognize it. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
nvywyerwer 发表于 2019-2-14 11:27 感谢您的快速回复,Algoss! 是的,探头部件号是N2795A。 我在本网站上看到了2009年的软件更新(v05.71)。 那么,有什么方法可以解决这个问题,保存升级范围或使用另一个探针? 也许某种手动配置? 该探针有时会工作,但仅在通道1上工作,即使范围从未识别它。 以上来自于谷歌翻译 以下为原文 Thank your for the quick reply, Algoss! Yes, the probe part number is N2795A. I saw a software update (v05.71) dated 2009 at this website. So, is there any way I could work around this issue, save upgrading the scope or using another probe? Maybe some kind of manual configuration? The probe works on occasion, but only on channel 1 even though the scope never recognizes it. |
您需要一个不同的(较旧的)探测器或一个不同的(较新的)范围。 示波器使用串行连接来识别探针。 如果无法识别探针,则无法使用。 人 以上来自于谷歌翻译 以下为原文 You need either a different (older) probe, or a different (newer) scope. The scopes use a serial connection to recognize the probe. If the probe isn't recognized, it won't work. Al |
1596 浏览 0 评论
2549 浏览 1 评论
2420 浏览 1 评论
2255 浏览 5 评论
3189 浏览 3 评论
999浏览 0评论
1596浏览 0评论
GMT+8, 2025-7-1 09:26 , Processed in 1.458235 second(s), Total 81, Slave 65 queries .
