扫一扫,分享给好友
你好,
现在的PSOC5硅可用性的官方版本是什么? 我知道在评估工具包中有一些,但是问题是关于大众可用的集成电路。 大约6个月前,我答应了样品,什么也没发生(不得不使用史密斯)。其他项目 竞赛是一个很好的方法让PSoC5通过展示你可以用它做什么,但如果没有硅。 这有什么意义呢? 当做 简 以上来自于百度翻译 以下为原文 Hi, What is now the official version of silicon availability of PSoC5? I know there is a few of them on evaluation kits, but the question is about the IC available to the masses. I was promised samples about 6 months ago and nothing happened (had to use smth. else for the project) The contest is a good way to make PSoC5 popular by showing what you can do with it, but if there is no silicon what is the point of it? Regards Jan |
你好,简,
这场比赛使用的是我们所说的“ES1”硅。工程样品的ES代表。我们不接受批量订单,今天,但我们航运这种硅在我们所有的开发包,和样品供客户。 客户可以通过联系当地的销售代表订购样品(分布)。我们今天抽样的两部分数字是: CY8C568AXI-060ES1 CY8C358LTI-114ES1 我希望这有帮助。 -博比 以上来自于百度翻译 以下为原文 Hi Jan, This contest is using what we refer to as "ES1" silicon. The ES stand for engineering samples. We're not accepting volume orders today, but we are shipping this silicon on all of our development kits, and samples are available for customers. Customers can ordering samples by contacting their local sales representative (including distribution). The two part numbers we are sampling today are: CY8C5588AXI-060ES1 CY8C5588LTI-114ES1 I hope that helps. -Bobby |
你好,
一旦这些设备全部生产,这些设备的价格会是多少?一些近似的成本将是有益的。谢谢 以上来自于百度翻译 以下为原文 Hello, What will be the price of these devices once they are in full production? Some approximate cost would be helpful. Thanks |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 17:39 , Processed in 0.676128 second(s), Total 48, Slave 42 queries .
