我有一些问题试图添加一个新的窗口分辨率与FX3 SDK。我们使用的是CX3开发套件的易控系统。
在Cypress EZ USB套件,我能够导入一个项目拿到相机跑,但我有一些问题,添加新的分辨率设置。我想用最大的分辨率,但在一个不寻常的纵横比。相机的OV5640,它有一个最大分辨率2592x1944,但我想用这个在6:1和4:1的纵横比。我想这样做,我们可以在最大分辨率更高的帧速率。 当打开”。cycx”文件,我可以看到的设置,但文件是不可编辑的。有没有一种方法来添加一个新的决议进入这个文件吗?它看起来像是锁什么的。任何帮助或提示就好了。 我已经附上屏幕截图的问题。+和-按钮添加配置锁定的一些原因。 捕获1.PNG 52.9 K 捕捉器 26.3 K 以上来自于百度翻译 以下为原文 I am having some issues trying to add a new windowed resolution with the FX3 SDK. We are using the CX3 dev kit by e-con systems. In the Cypress EZ USB Suite, I am able to import a project and get the camera running, but I am having some issues adding new resolution settings. I'd like to use the maximum resolution, but at an unusual aspect ratio. The camera is the OV5640, which has a max resolution of 2592x1944, but I'd like to use this at a 6:1 or 4:1 aspect ratio. I'd like to do this so that we can get higher frame rates at the max resolution. When opening the ".cycx" file, I can see the settings, but the file is not editable. Is there a way to add a new resolution entry to this file? It looks like it is locked or something. Any help or hints would be great. I've attached screen shots of the issue. The + and - buttons to add configurations are locked out for some reason.
请使用FX3SDK的更新版本。在我的结尾,我有这个选择。
请尝试:a)通过创建一个具有不同名称的新配置(在配置工具中选择预定义的配置,该项目具有不同的名称)。请在快照中看到关于更改的地方。 b)也可以使用基本和自定义模式来设置工具中的设置。 CX3.JPG 104.1 K 以上来自于百度翻译 以下为原文 Please use the updated version of the FX3 SDK. I get this option at my end. Please try: a) by creating a new configuration with a different name (select predefined configuration in the config utility with a different name for the project). Please see in the snapshot about where to make changes. b) You can use basic and custom mode as well to set your setting in the tool.
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 12:36 , Processed in 0.582806 second(s), Total 45, Slave 40 queries .
