你好,
我正在评估L6470作为已停产芯片的替代品,目前已在我们的应用中使用。 我必须达到高速(2500步/秒),但是当超过800步/秒时,电机会失步。以下是我的电机特性:根据数据表: Rm = 0,8欧姆 Lm = 1 mH (我测量的Rm = 3,3欧姆; Lm = 5.3 mH) ke = 0,115 V / Hz 我用的是24V电源。 我用dSPIN评估工具尝试了很多不同的参数,但800步/秒似乎是上限,尽管旧的电机驱动器很容易达到2500步/秒。 有人对我有暗示吗? 顺便说一下,我正在评估EVAL6470H板。 问候, 斯特凡 以上来自于谷歌翻译 以下为原文 Hello, I am evaluating the L6470 as replacement for a discontinued chip, which is used in our application in the moment. I have to reach high speed (2500 step/s), however when going above 800 step/s the motor looses steps. Here are my motor characteristics: according to datasheet: Rm = 0,8 Ohm Lm = 1 mH (I measured Rm = 3,3 Ohm; Lm = 5,3 mH) ke = 0,115 V/Hz I use 24V power supply. I tried a lot of different parameters with dSPIN Evaluation tool, but 800 step/s seems to be the upper limit, although the old motor driver reaches 2500 step/s easily. Does anyone have a hint for me? BTW, I'm evaluating with EVAL6470H board. regards, Stefan |
3个回答
你好Stefan,
这个问题可能与电机的中速共振有关。如果电机卸载,我建议你在轴上加一个小负载(例如加几圈胶带),这样谐振应该稍微减弱,避免步进损失。 BR 恩里科 以上来自于谷歌翻译 以下为原文 Hello Stefan, the issue is probably related to the mid-speed resonance of the motor. If the motor is unloaded I suggest you to add a small load on the shaft (e.g. adding few rounds of adhesive tape), this way the resonance should be dampen a bit and the step-loss is avoided. BR Enrico |
嗨,恩里科,
谢谢你的快速回复。无论有无负载,我都试过了,但没有区别。我看了一下示波器,发现当前的峰值不在步骤的中心(见附件)这是正常的吗?如果没有,哪个参数改变了这种行为? 以上来自于谷歌翻译 以下为原文 Hi, Enrico, thanks for your fast reply. I tried both, with and without load, but there is no difference. I took a look at the oscilloscope and found that the current peak is not in the center of the step (see attached file) Is that normal? If not, which parameter changes this behavior? |
嗨Stefan,
输出电压和电机电流之间的相位关系取决于电机的电气特性和机械负载,因此波形正常。 你试着增加电机电流吗?也许仅保持电机以该速度运转是不够的。 问候 恩里科 以上来自于谷歌翻译 以下为原文 Hi Stefan, The phase relation between the output voltage and the motor current depends on the electrical characteristics of the motor and the mechanical load, so the waveforms are ok. Did you try to increase the motor current? Maybe it is not enough to keep the motor running at that speed. Regards Enrico |
2821 浏览 1 评论
3262 浏览 1 评论
1838 浏览 1 评论
3687 浏览 6 评论
6091 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
391浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
481浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
312浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
228浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
333浏览 2评论
GMT+8, 2025-2-1 07:40 , Processed in 0.989606 second(s), Total 50, Slave 44 queries .
