嗨,所有,我们已经提出了一个用于所有SRAM的结温度计算器工具,便于计算在SRAMs的最大结温。我已经附加了ZIP文件的结点温度计算器工具的beta版本。该异步工具适用于NVSRAM和异步SRAM。同步工具将适用于同步SRAM。请提供您的意见。问候,Pavan
以上来自于百度翻译 以下为原文 Hi All, We have come up with a Junction temperature Calculator tool for all SRAMs for ease of use in calculating the Maximum Junction temperature in SRAMs. I have attached zip file of the beta version of Junction temperature calculator tool below. The Async tool will be applicable for NVSRAM and Asynchronous SRAMs. The Sync tool will be applicable for Synchronous SRAMs. Do provide your comments. Regards, Pavan |
嗨,所有的,这将是伟大的,如果你可以发表一些意见/改善这个结点温度计算器工具。等待你宝贵的反馈,Pavan
以上来自于百度翻译 以下为原文 Hi All, It would be great if you can post some comments/improvements on this junction temperature calculator tool. Waiting for your valuable feedback, Pavan |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 13:35 , Processed in 2.950454 second(s), Total 78, Slave 62 queries .
