扫一扫,分享给好友
我需要在我的设计中使用剪切通过USB / DMA模式。有没有其他的例子或更详细的附录?背景:我想使用两个512字节的ISO端点。PSoC 3中的最大端点缓冲区总共为512字节,因此,每个端点只能使用256字节的端点缓冲区。通过使用直通USB模式,PSoC 3只保留端点缓冲器中的端点数据的一部分,从而可以模拟多达1023字节的端点缓冲器。随着数据被发送到主机,从RAM到端点缓冲器的数据越来越多。非常好,但很少的文件可用。
以上来自于百度翻译 以下为原文 I need to use the cut-through USB/DMA mode in my design. Is there any example or more detailed appnote available? Background: I want to use two 512 byte ISO endpoints. The maximum endpoint buffer in the PsoC 3 is in total 512 byte so i can only use a 256 byte endpoint buffer per endpoint. By using cut-through USB mode, the PSoC 3 will only keep part of the endpoint data in the endpoint buffer such that up to 1023 byte endpoint buffers can be simulated. As data is being sent to the host, more data is being DMAed from RAM to the endpoint buffer. Very nice but very little documentation available. |
有一个在使用USB接口的几个应用笔记和DMA一应用笔记(an52705),但我不知道一个覆盖正是你所寻找的。DMA应用笔记是最近刚刚发布了(1/13)。你有了任何现有的DMA &;USB应用注释?-博比
以上来自于百度翻译 以下为原文 There are a few app notes on using USB, and one app note on DMA (AN52705), but I am unaware of one that covers exactly what you are looking for. The DMA app note was just recently released (1/13). Have you reviewed any of the existing DMA & USB app notes? -Bobby |
是的,我已经梳理过所有的应用笔记,但没有覆盖覆盖通过USB模式。显然,固件需要将DMAC设置为“端点”数据,并且DMAC需要将更多的数据发送到USB块,因为数据正被发送到主机(EP中的USB)。然而,如何将TDS配置为切入模式是完全没有记录的。我试图找出这一困难的方式,但我将非常感激,如果可以产生一个例子,将减少猜测。谢谢。
以上来自于百度翻译 以下为原文 Yes, I have combed through all app notes but nothing covers cut-through USB mode. It is clear that the firmware needs to setup the DMAC to "prime" the endpoint with data and that the DMAC needs to send more data to the USB block as data is being sent to the host (USB IN EP). It is, however, completely undocumented HOW to configure the TDs to work with cut-through mode. I am trying to figure this out the hard way but i would very much appreciate if an example could be produced that would cut down on the guesswork. Thanks. |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3421 浏览 0 评论
2301 浏览 1 评论
2020 浏览 1 评论
3864 浏览 1 评论
1921 浏览 6 评论
4065浏览 2评论
2586浏览 2评论
583浏览 2评论
560浏览 2评论
4342浏览 2评论
GMT+8, 2025-7-12 18:17 , Processed in 1.104201 second(s), Total 46, Slave 40 queries .
