嗨,我是一个新的程序员在PIC24F微,我想问我如何设置特定的端口引脚作为输出,而不改变其他端口上的端口。例如,如果我想要以下配置:TrISB位6至13需要输出,所有其他位保持不变。T没有单独设置每个引脚?(像三位一体。TrISB6=0)…谢谢
以上来自于百度翻译 以下为原文 Hi, I'm new programmer on a PIC24F micro and I wanted to ask how can I set specific port pins as output without changing the other pins on that port. For example if I want the following configuration: TRISB bits 6 to 13 need to be output and all the other bits remain unchanged. There is a way to do that without set each pin individually? (Like TRISBbits.TRISB6 = 0...) Thanks |
3个回答
以上来自于百度翻译 以下为原文 TRISB = 0xC03F; //or provided you have other settings you want to keep: TRISBbits.TRISB6 = 0; TRISBbits.TRISB7 = 0; TRISBbits.TRISB8 = 0; TRISBbits.TRISB9 = 0; TRISBbits.TRISB10 = 0; TRISBbits.TRISB11 = 0; TRISBbits.TRISB12 = 0; TRISBbits.TRISB13 = 0; |
否则会留下其他的位子作为他们事先(无论是什么)。苏珊
以上来自于百度翻译 以下为原文 or TRISB &= 0xc03f; which will leave the other bits as they were beforehand (whatever that was). Susan |
5385 浏览 9 评论
2107 浏览 8 评论
2009 浏览 10 评论
3285 浏览 3 评论
2319 浏览 5 评论
890浏览 1评论
780浏览 1评论
715浏览 1评论
775浏览 0评论
666浏览 0评论
GMT+8, 2025-3-11 06:51 , Processed in 1.161955 second(s), Total 51, Slave 45 queries .
