有些是在和谐文件夹中的代码。剩下的是图书馆。我认为它没有来源。(但我可能错了)
以上来自于百度翻译 以下为原文 Some is code that is in the harmony folders. The rest is a library. I do not think it has source. ( but I could be wrong) |
嗨,大部分的外围层代码是在内联函数中驻留在头文件:*.h,在目录:Microchip / Harmont /V2Y03B/框架/外围设备……当程序被编译为优化1或更高时,内联被执行,并且当调试时,源代码视图可能从O中跳出来。NE到下一个函数,不显示它是如何到达的。当程序没有优化编译时,函数从一个对象库存档文件中加载。但是调试器大多是残缺不全的,不能在库函数中显示源代码,所以调试器源代码从一个函数C中跳出来。所有的下一个,没有显示什么正在进行的功能。迈西尔
以上来自于百度翻译 以下为原文 Hi, Most of the peripheral layer code in Harmony is in Inline functions that reside in Header files: *.h, in directory: Microchip/Harmont/v2_03b/framework/peripheral/... When program is compiled with optimization 1, or higher, inlining is performed, and when debugging, source code view may jump from one function to the next, without showing how it get there. When program is compiled with no optimization, functions are loaded from a object library archive file. But the debugger is mostly crippled, Not able to show source code in library functions, so debugger source code jumping from one function call to the next, without showing what is going on inside functions. Mysil |
继续Mysil所说的,你可以在“Microchip/Harmont /V2Y03B/框架/外围设备/目录”中寻找“模板”文件夹。这就是PLIB发生寄存器操作的地方。
以上来自于百度翻译 以下为原文 to continue with what Mysil said, you can look for "template" folder inside "Microchip/Harmont/v2_03b/framework/peripheral/" directory. that is where register manipulation happens for PLIBs. |
5379 浏览 9 评论
2105 浏览 8 评论
2007 浏览 10 评论
3283 浏览 3 评论
2317 浏览 5 评论
888浏览 1评论
778浏览 1评论
714浏览 1评论
772浏览 0评论
663浏览 0评论
GMT+8, 2025-3-9 21:08 , Processed in 1.269086 second(s), Total 78, Slave 62 queries .
