大家好,你们中有人试图在SD卡上创建有或没有FATFS代码的Excel文件吗?是否可以在SD卡上创建Excel文件而不是.text文件?
以上来自于百度翻译 以下为原文 Hi All, Have any of you maybe tried to create an Excel file with or without FatFS code on a SD card? Is it possible to create an Excel file on a SD Card instead of a .text file? |
5个回答
可以创建任何类型的文件,这完全取决于如何将数据写入文件。这取决于你。SD卡并没有真正进入它。如果你要写一个Excel文件的例子,那就不同了。
以上来自于百度翻译 以下为原文 It is possible to create any type of file, it all depends on how you write the data to the file. This is up to you. The SD card doesn't really enter into it. If you are asking for an example of writing an Excel file then that is different. |
可以创建任何类型的文件,这完全取决于如何将数据写入文件。这取决于你。SD卡并没有真正进入它。如果你要写一个Excel文件的例子,那就不同了。什么是Excel文件?XLS?XLSX?CSV?你为什么要用它?哪些文件格式特性对你很重要?(你不能用TXT做什么)
以上来自于百度翻译 以下为原文 It is possible to create any type of file, it all depends on how you write the data to the file. This is up to you. The SD card doesn't really enter into it. If you are asking for an example of writing an Excel file then that is different. What is an Excel File for you ? xls ? xlsx ? csv ? Why do you need to use it ? Which of the file format features are important for you ? (what you can't do with .txt ) |
嗨,最简单的方法是用一个由冒号或分号分隔的值来做一个TXT文件。Excel可以非常容易地导入这些文件;
以上来自于百度翻译 以下为原文 Hi, The easiest way is to do a txt file with values separated by colon or semicolon. EXCEL can import these files very easily ;=) Regards |
我同意RISC。这正是我们在产品上所做的。下面是我们使用FATFS库处理SD卡上的XXX.CSV文件的一个例子来处理文件系统。如果将文件从SD卡传输到PC并双击它,Excel将打开,数据将以行和列显示。
以上来自于百度翻译 以下为原文 I agree with RISC. This is exactly what we do on our product. Here is an example of the data we write to our xxx.csv file on the SD card using the FatFs library to handle the file system. If you transfer the file from the SD card to a PC and double click on it, excel will open and the data will be displayed in rows and columns "Latitude","Longitude","SNR","Rpt ID","Site ID","Channel","Rpt Lat","Rpt Long","Rpt SNR" 33.10403,-117.22009,1,"Any",0,1,33.10334,-117.21882,50 33.10406,-117.21903,81,"Any",0,1,33.10334,-117.21882,50 33.10447,-117.21776,35,"Any",0,1,33.10334,-117.21882,50 33.10351,-117.21762,74,"Any",0,1,33.10334,-117.21882,50 33.10396,-117.21968,71,"Any",0,1,33.10334,-117.21882,50 |
5318 浏览 9 评论
2073 浏览 8 评论
1978 浏览 10 评论
3250 浏览 3 评论
2286 浏览 5 评论
831浏览 1评论
724浏览 1评论
670浏览 1评论
723浏览 0评论
619浏览 0评论
GMT+8, 2025-2-1 06:56 , Processed in 0.953481 second(s), Total 52, Slave 47 queries .
