您好,首先,我使用MPLABX V3.61、Connect V2.03B、XC32 V1.43编译器和PIC32 MZ2048 EFM144。我正在研究一个需要与IPv4和IPv6连接的项目。我的IPv4完全工作,现在移动到IPv6。我可以从PC中提取这个设备,它的地址是由TCPIpHebug发现工具提供的,它的地址和套接字都是有效的。当试图通过浏览器和IPv6地址导航到索引页面时,它总是试图永远加载。我还使用了WiReSARK,可以看到从浏览器到设备看起来是什么有效的请求。有什么建议可以进一步诊断这个问题或者解决这个问题?谢谢!本
以上来自于百度翻译 以下为原文 Hello, First off I'm using MPLABX v3.61, HARMony v2.03b, XC32 v1.43 Compiler, and a PIC32MZ2048EFM144. I'm working on a project that requires to connect with IPv4 and IPv6. I have IPv4 working completely so moving onto IPv6 now. I am able to ping the device from a PC with the address given by the tcpip_discoverer tool that comes with harmony so the address and socket exist and are valid. When trying to navigate to the index page via a browser and the IPv6 address, it just keeps trying to load forever. I have also used Wireshark and can see what looks to be a valid request from the browser to the device. Any suggestions to further diagnose the problem or have a solution to this? Thanks! Ben |
3个回答
是否有可能在像WebSyServnnvMyMPFS这样的开箱即用项目上尝试?请让我们知道你发现什么,我们会尽力协助。
以上来自于百度翻译 以下为原文 Would it be possible to try this on an out of the box project like web_server_nvm_mpfs? Please let us know what you find and we'll try to assist. |
Runad,我忘了提到我确实这样做了,并且能够连接到那个确切项目的索引页面。我所有的配置都与IPv6和TCP的配置相匹配。谢谢!本
以上来自于百度翻译 以下为原文 rainad, I forgot to mention I actually did do this and was able to connect to the index page of that exact project. All my configurations in Harmony match the config for IPv6 as well as TCP. Thanks! Ben |
你说,同一个网页似乎与IPv4正常工作,所以可能没有错。你使用HTTP服务器:HTTP还是HTTPNET?请提供您的插件板的IPv6地址。
以上来自于百度翻译 以下为原文 So the out of the box project works and yours doesn't. You mentioned that the same web pages seem to work properly with IPv4 - so probably nothing wrong there. What HTTP server do you use: HTTP or HTTP_NET? P.S. Please provide the IPv6 address of your board. |
5066 浏览 9 评论
1946 浏览 8 评论
1880 浏览 10 评论
3106 浏览 3 评论
2177 浏览 5 评论
620浏览 1评论
496浏览 1评论
354浏览 1评论
522浏览 0评论
428浏览 0评论
GMT+8, 2024-9-23 13:23 , Processed in 1.256876 second(s), Total 82, Slave 66 queries .
