扫一扫,分享给好友
在浏览收费管理员的文件时,我偶然发现了PowerPSoC。谁能告诉我PSOC1和PowerPSoC有什么不同?他们都有相同的核心?
以上来自于百度翻译 以下为原文 While going through the document on Charge Controller, I came across PowerPSoC. Can anyone tell me what is the difference between PSoC1 and PowerPSoC? Do they both have the same core? |
4个回答
事实上,PSOC1的电源PSOCS家族成员是MC8核心。此外,它们包含一些用于直接控制介质电流或驱动MOSFET的更高电流要求的读出放大器和DRIVE输出。请在这里打开一个应用说明:HTTP://www. CyPress?COM/?ID=2308和rTID=76
让阳光照进来… 鲍勃 以上来自于百度翻译 以下为原文 Indeed are the Power-PSoCs family members of PSoC1 with an MC8-Core. Additionally they contain some sense-amplifiers and dirve outputs for directly controlling medium currents or driving MOSFETs for higher current requirement. I Suggest you to open one of the application notes here:http://www.cypress.com/?id=2308&rtID=76 Let the sunshine in... Bob |
当你查看一个电力PSoC的数据表时,你会看到这里有一个完整的块专用于电力PopopHeles。所以,你可能需要添加一些驱动程序和粘贴逻辑到PSoC1芯片来获得你想要的…
当然,只要没有特殊的硬件,你就可以在任何其他PSoC中使用C语言编写的任何算法。你在哪里发现提到MPPT在附注? 鲍勃 以上来自于百度翻译 以下为原文 When you have a look at the datasheet for a power-PSoC you'll see that there is a complete block that is dedicated to the power-peropherals here. So it might be that you'll have to add some driverts and glue logic to a PSoC1 chip to get what you desire... Of course you can use any algorithm written in C on any other PSoC as long as there is no special hardware involved. Where did you find the mentioning of MPPT in the appnotes? Bob |
PoPPSoC可以被看作是“PSoC1+电源外设”。功率外设主要是FET、栅极驱动器、滞环控制器、电流灵敏放大器、专用比较器和DACS。另一部分[PSoC1]具有典型PSOC1的数字和模拟特性。
以上来自于百度翻译 以下为原文 PowerPSoC can be seen as 'PSoC1 + Power peripherals'. The Power peripherals are mainly FETs, Gate drivers, Hysteretic controller, Current Sense Amplifier, dedicated Comparators and DACs.The other part[PSoC1] has the digital and analog capabalities of a typical PSoC1. |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3139 浏览 0 评论
2290 浏览 1 评论
2014 浏览 1 评论
3856 浏览 1 评论
1914 浏览 6 评论
3791浏览 2评论
2316浏览 2评论
578浏览 2评论
555浏览 2评论
4060浏览 2评论
GMT+8, 2025-7-6 07:03 , Processed in 1.082814 second(s), Total 83, Slave 67 queries .
