虽然没有具体的例子,但是我试图用另一块板上的spc56ELxx OSLess CAN例子做一些事情,即使LED闪烁,也没有生成CAN数据。
我真的很感激,如果我能让这个工作。 关于FlexRay,有没有可用的资源? 谢谢! #罐spc56el70l5-的FlexRay 以上来自于谷歌翻译 以下为原文 Appart from the fact that there are no specific examples for it, i have tried to do something with spc56ELxx OSLess CAN example from another board, and even though leds blink, there is no CAN data generated. I would really appreciate if i could get this to work. And regarding FlexRay, are there any resources available for it? Thanks! #can-spc56el70l5-flexray |
8个回答
嗨,
现有的CAN演示使用内部环回模式,消息在内部交换,因此外部无法看到任何内容。 如果您需要将演示适配到另一个板,请按以下步骤操作: - 在“项目浏览器”中复制/粘贴CAN项目并为其命名(可选)。 - 打开configuration.xml .. - 选择“驱动程序”组件,进入CAN部分并打开您在那里看到的唯一配置,取消选择环回模式。 - 选择“板”组件并使用配置视图中的“打开”图标加载电路板的预设,这将为您的电路板设置IO。您不需要其他设置,因为两块板具有相同的振荡频率。 - 再次在电路板组件中,您必须为CAN设置CAN引脚,请参见参考手册和电路板原理图。 乔瓦尼 以上来自于谷歌翻译 以下为原文 Hi, The existing CAN demos use an internal loopback mode, messages are exchanged internally so nothing is visible outside. If you need to adapt a demo to another board, proceed as follow: - Copy/paste the CAN project in the ''Project Explorer'' and give it a new name (optional). - Open configuration.xml.. - Select the ''drivers'' component, go in the CAN section and open the only configuration you see there, unselect the loopback mode. - Select the ''board'' component and load the preset for your board using the ''open'' icon in the configuration view, this will setup IOs for your board. You don't need other settings because the two boards have the same oscillatory frequency. - In the board component again you have to setup the CAN pins for CAN, see the Reference Manual and the board schematic. Giovanni |
嗨,
组装在电路板上的CAN-DB9部件连接方式错误。要解决此问题,您必须添加适用的附图。 马尔科 以上来自于谷歌翻译 以下为原文 Hi, The CAN - DB9 part assembled in the board is connected in wrong way. To solve the problem you have to add an adapted as indicated in the attached picture. Marco |
非常感谢,我将在今天下午进行测试,然后回来查看结果。
顺便问一下,FlexRay怎么样? 问候, 哈维尔 以上来自于谷歌翻译 以下为原文 Thank you very much, i will test it this afternoon and come back with results. By the way, what about FlexRay? Regards, Javier |
嗨,
此时,SPC5Studio尚未规划FlexRay支持。适用于SPC5器件的AUTOSAR MCAL封装中提供FlexRay驱动程序。 乔瓦尼 以上来自于谷歌翻译 以下为原文 Hi, FlexRay support is not planned for SPC5Studio at this point. A FlexRay driver is available in the AUTOSAR MCAL package for SPC5 devices. Giovanni |
你好,
FlexRay有什么变化吗?那有什么例子吗? 大卫 以上来自于谷歌翻译 以下为原文 Hello, were there any changes regarding FlexRay? Are there any examples for that? David |
对不起大卫,
目前,还没有计划发布SPC5Studio。 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Sorry David , At the current time, it is not planned for SPC5Studio release. Best Regards Erwan |
大卫你好,
在大众市场的观点(RLA& HAL),我们没有FlexRay驱动程序 关于SPC56 L上的AUTOSAR MCAL,您可以在以下链接中找到一些信息。 https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/spc5-embedded-software/stsw-spc56as002.license%3d1497601240928.html 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello David , on Mass Market point of view (RLA & HAL), we have no FlexRay drivers About AUTOSAR MCAL on SPC56 L, you can find some information on this following link. https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/spc5-embedded-software/stsw-spc56as002.license%3d1497601240928.html Best regards Erwan |
你好,
但据我了解,仍然可以使用flexray吗? 乔万尼提到了 适用于SPC5器件的AUTOSAR MCAL封装,这究竟是什么?这是FlexRay的驱动程序吗? 这是st商品还是来自第三方? 提前致谢, 大卫 以上来自于谷歌翻译 以下为原文 Hello, but as far as I understand it still is possible to make use of flexray right? Giovanni mentioned the AUTOSAR MCAL package for SPC5 devices, what is this exactly? Is this the drivers for FlexRay? Is this something st offers or from a third party? Thanks in advance, David |
2597 浏览 1 评论
3199 浏览 1 评论
1773 浏览 1 评论
3595 浏览 6 评论
5977 浏览 21 评论
927浏览 4评论
1303浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
572浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1291浏览 3评论
1344浏览 3评论
GMT+8, 2024-11-13 10:19 , Processed in 1.024451 second(s), Total 56, Slave 51 queries .
