我们从element14 .. L6388ED,L6390,L6386购买了IGBT驱动IC ......所有这些IC都没有找到任何标记,哪个引脚是No.1。通常所有IC都有点标记,表示IC顶部有PIN.NO.1或U标记。
但ST驱动器IC没有任何标记。 我焊接了IC L6388ED并通过假设引脚编号在两个方向上给出了电源。它不起作用。我认为由于PIN-OUT编号错误导致IC损坏。 帮我找PIN-OUT .. #l6388#l6386#l6390 以上来自于谷歌翻译 以下为原文 We bought IGBT driver ICs, from element14.. L6388ED, L6390, L6386...all those ICs dont have any markings to find, which pin is No.1. Usually all ICs have dot mark to indicate PIN.NO.1, or U mark at the top of IC. But the ST driver ICs dont have any markings. I soldered IC L6388ED and given the supply by assuming pin numbers, in both direction. Its not working. I think that IC is damaged due to mis-numbering of PIN-OUT. Help me to find PIN-OUT.. #l6388 #l6386 #l6390 |
你好,
当IC /芯片没有标记时,简单的方法是将其水平保持,使得写入从左到右,现在引脚1是左下角的引脚。 上述设备在其数据表中报告了封装尺寸,在这里您可以看到SO封装具有斜边。 将斜边保持在底部,第1号引脚是左下角的引脚。 问候, CRISTIANA 以上来自于谷歌翻译 以下为原文 Hello, when the IC/Chip has got no markings the simple way is hold it horizontally so that the writing is from left to right and now the pin no 1 is the one on the bottom left. The mentioned device reports in their data sheet the package dimensions, here you can see that the SO package have a beveled edge. Keeping the beveled edge at the bottom, the pin no 1 is the one on the bottom left. Regards, Cristiana |
2875 浏览 1 评论
3281 浏览 1 评论
1861 浏览 1 评论
3707 浏览 6 评论
6117 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
353浏览 2评论
GMT+8, 2025-2-23 07:30 , Processed in 1.095700 second(s), Total 75, Slave 59 queries .
