嗨,我在使用IDES方面有一些经验。我很感激MPLABX和和谐的努力。但是,很多很多的错误让他们使用了酷刑。如果你想做更复杂的事情,那就是…尴尬。“连接失败”(在PICtiT3)几分钟后。重新启动MPLABX后,很好,没有找到调试工具…没有理由,在重新启动MPLABX之后,PACKIT3工作正常。许多错误警报/错误通知。断点是垃圾(很多时候当他们拒绝放或保存它们)…重新启动后,工作正常。我认为你没有正确的方向发展。
以上来自于百度翻译 以下为原文 Hi, I have some experience in using IDEs. And I appreciate the effort to make MPLABX and HARMony. But many , many errors make their use a torture. For simple things, it's good. If you want to do something more complex, it's ... embarrassing. "Connection failed" (at PICkit3) after a few minutes. after restarting MPLABX, it's good. Debugging tools were not found ... for no reason, after restart mplabx, pickit3 work Ok. Many false alert / error notifications. Breakpoints are garbage (many times when they refuse to put them or hold them)... after restart, works Ok. I think you are not in the right direction with this development. |
你的期望是什么?简单地说,如果你不喜欢和声,请自己写代码。像许多人一样
以上来自于百度翻译 以下为原文 What is yours expectations? In Simple If you don't like harmony Write your code by own. Like many do |
嗨,你用的是PIC32?PICTIT3在编程大型闪存设备时非常慢,因此它可能不是开发PIC32的正确工具。我通常使用ICD3或PIC32和声项目的实际ICE,因为Flash图像一旦使用协议栈就变得大了……而且我不想等待一对MN进行PROG。此外,PICTIT3不支持SW断点或数据断点
以上来自于百度翻译 以下为原文 Hi, Which PIC32 do you use ? Pickit3 is very slow at programming large flash devices so it is probably not the right tool to use to develop PIC32... I generally use ICD3 or Real-Ice with PIC32 harmony projects because flash images become large as soon as you use protocol stacks...and I don't want to wait a couple of mn for programming ;=) Additionally Pickit3 does not support SW breakpoints or data breakpoints Regards |
5262 浏览 9 评论
2044 浏览 8 评论
1960 浏览 10 评论
3221 浏览 3 评论
2271 浏览 5 评论
799浏览 1评论
692浏览 1评论
626浏览 1评论
690浏览 0评论
589浏览 0评论
GMT+8, 2025-1-1 23:28 , Processed in 1.078048 second(s), Total 80, Slave 64 queries .
