你好,
从“编程EZ-USB®FX3μC处理器端口作为同步从FIFO”的应用模式来看,如果选择SPI,则不支持32位数据总线宽度。启动后,我使用SPI(GPIO(53)-SPILSCK和GPIO(56)-SPIXMOSI)来配置FPGA,然后使GPFI到32位从FIFO模式,显然是可行的。在固件运行时,我想再次用SPI接口重新配置FPGA,但在那个时候,GPIF是32位从FIFO模式,我可以停止GPIF或切换到16位模式,使用SPI重新配置FPGA,SWtiTCH到32位奴隶FIFO吗? 谢谢您! 以上来自于百度翻译 以下为原文 Hi, From the application mode of "Programming EZ-USB® FX3™ Processor Port as Synchronous Slave FIFO", 32 Bit data bus width is not supported if SPI is selected. After bootup, I use SPI (GPIO[53] - SPI_SCK and GPIO[56] - SPI_MOSI) to configure FPGA, then I enable GPFI to 32-bit slave FIFO mode, it is obviously doable. During firmware runtime, I want to re-configure FPGA with SPI interface again, but at that monent, GPIF is 32-bit slave FIFO mode, Can I stop GPIF or switch to 16-bit mode, using SPI re-configure FPGA, and swtich to 32-bit slave FIFO again? Thank you! |
嗨,Yi,
当心这个帖子 HTTP://www. CyPress?COM/?APP =论坛和ID ID=167和;RID=58084 在这个岗位上 HTTP://www. CyPress?COM/?APP =论坛和ID ID=167和;RID=60662 然后它应该在各个方向工作。 当做 隆皮 以上来自于百度翻译 以下为原文 Hi Yi, Take care on this post http://www.cypress.com/?app=forum&id=167&rID=58084 And on this post http://www.cypress.com/?app=forum&id=167&rID=60662 Then it should work in all directions. Regards Lumpi |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
274浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 21:18 , Processed in 0.692028 second(s), Total 46, Slave 40 queries .
