嗨,
我对STM8S等待状态有疑问。当执行完全等待状态时 - 每次访问XFLASH或每个指令源? 我想用24Mhz晶体振荡器(1等待状态)为我的MCU提供时钟,我需要知道与16MHz时钟(0等待状态)相比,速度增益是多少。在等待状态打开时,循环确认多少指令?我无法找到有关此主题的任何信息。 谢谢, 帕维尔 以上来自于谷歌翻译 以下为原文 Hi, I have question regarding STM8S wait states. When exactly wait states are executed - every access to XFLASH or every instruction feed? I want to clock my MCU with 24Mhz crystal oscilator (1 wait state) and I need to know what will be the speed gain in comparison with 16MHz clock (0 wait states). How much instructions are cycle acurate while wait states are on? I cant find any information on this topic. Thanks, Pawel |
帕维尔,
将STM8内核计时到24 MHz可以提高性能,但实际增益会因应用而异,必须使用示波器进行测量,因为STM8流水线和XFLASH的32位宽总线混淆了任何时钟周期数。 当内核以24 MHz运行时,XFLASH无法如此快速地响应STM8内核。因此需要等待状态。 当添加等待状态时,每个XFLASH访问在24 MHz时大约需要83 ns,但这种减速可能不会影响性能,因为返回了四个字节。 如果您的代码包含占地面积小的操作码(例如,INC A,MUL X,A DIV XY等单字节指令),则没有真正的XFLASH性能损失,因为XFLASH数据提取为STM8解码流水线提供了足够的数据并且这种惩罚平均最多四条指令。 当XFLASH不是瓶颈时,处理速度肯定会有所增加,但正如我之前所写,这种增益取决于你的代码。 在我看来,如果你需要更多的计算能力,你可以选择STM32,或者如果你只需要很小的速度改进,你可以重新编码你的算法。 您也可以从RAM(不需要等待状态)执行代码,但这样做的代码和数据管道必须共享同一个只有8位宽的总线。 在我看来,16 MHz时钟是更好的选择。 问候, EtaPhi 以上来自于谷歌翻译 以下为原文 Pawel, clocking the STM8 core to 24 MHz may improve performance, but the real gain changes from application to application and must be measured with an oscilloscope because the STM8 pipeline and the 32 bit wide bus of XFLASH muddle any clock cycle count. When the core is running at 24 MHz, XFLASH can't respond to STM8 core so quickly. A wait state is therefore needed. When a wait state is added, each XFLASH access takes about 83 ns @ 24 MHz, but this slowdown may not impact performance, as four bytes are returned. If your code consists in small footprint opcodes (eg. one-byte instructions like INC A, MUL X,A DIV X.Y etc) there is no real XFLASH performance penalty since a XFLASH data fetch provide enough data to the STM8 decode pipeline and this penalty is averaged on at most four instructions. When XFLASH isn't a bottleneck, there is a sure gain in processing speed but this gain, as I wrote before, depends on your code. In my opinion, if you need more computing power, you may choose a STM32 or if you need only small speed improvements, you can recode your algorithms. You can also execute your code from RAM (which doesn't need a wait state), but doing so the code and data pipelines must share the same bus which is only 8 bit wide. In my opinion, a 16 MHz clock is a better choice. Regards, EtaPhi |
2881 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3711 浏览 6 评论
6125 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-24 11:07 , Processed in 0.998383 second(s), Total 43, Slave 38 queries .
