我成功地使用34980A主机远程(使用labview)对某些硬件进行了近30K的DMM 2线电阻测量。
一切都很好,除了警报蜂鸣器持续响起。 此外,前面板错误指示灯持续亮(我不在乎)。 为什么报警开启以及如何关闭? Thanx DaniDin 以上来自于谷歌翻译 以下为原文 I am successfully using the 34980A mainframe to remotely (using Labview) take almost 30K DMM 2-wire resistance measurements of some HW. All's well except that the AlARM buzzer continuously sounds off. In addition, the front panel Error indicator is continuously On (which i don't care). Why is the Alarm on and how, do I turn off? Thanx DaniDin |
只有当您的LabView程序首次启用34980A报警功能时,才会发生这种情况。
如果在LabView程序中无法轻松找到它,请从MAX开始监视程序并查找OUTP:ALAR:MODE,STAT:ALAR:ENAB和/或其他34980A SCPI命令,其中包含“ALAR” 从您的LabView程序发送的。 34980A可以输出一个“蜂鸣声”以响应SYST:BEEP命令。 还有可以驱动的警报输出线和外部蜂鸣器,但34980A中没有蜂鸣器。 以上来自于谷歌翻译 以下为原文 This can only happen if your LabView program first enabled the 34980A alarm function. If you can't find it easily in your LabView program, monitor the program from the beginning from MAX and look for the OUTP:ALAR:MODE, STAT:ALAR:ENAB, and/or other 34980A SCPI commands with "ALAR" in them that are being sent from your LabView program. The 34980A can output one "beep" in response to a SYST:BEEP command. There are also alarm output lines that can drive and external buzzer, but there is no buzzer in the 34980A. |
lanziji 发表于 2019-1-28 14:09 Tomc感谢你看一下。 那个东西有蜂鸣器和蜂鸣器吗? 我可能应该说嘟嘟声不是嗡嗡声:-)无论如何,我没有任何明确的LV功能,也没有发送任何涉及蜂鸣器和/或蜂鸣器的SCPI命令。 我开始使用* CLS和重置命令到instr,然后是一堆继电器关闭/打开和DMM电阻测量。 “-410 Query Interrupted”错误消息是否与哔声有关? 同样,除了嘟嘟声很烦人之外,对程序执行没有相应的影响。 以上来自于谷歌翻译 以下为原文 Tomc Thanks for taking a look at that. Is there a buzzer, and a beeper in that thing? I probably should have said beeps not buzzes :-) Anyway, I don't have any explicit LV functions, nor do I send any SCPI commands that involve buzzers and/or beepers. I start off with the *CLS and Reset commands to the instr, followed by a bunch of relay closes/opens and DMM Resistance measures. Does the "-410 Query Interrupted" error message have anything to do with the beeps? Again, other than the fact that the beeps are annoying, there is no corresponding effect to the program execution. |
1033 浏览 0 评论
2278 浏览 1 评论
2065 浏览 1 评论
1937 浏览 5 评论
2808 浏览 3 评论
802浏览 1评论
588浏览 0评论
684浏览 0评论
2470浏览 0评论
1523浏览 0评论
GMT+8, 2024-9-21 12:27 , Processed in 1.131838 second(s), Total 47, Slave 42 queries .
